Front Brake Line Question
Can you use 73-87 Chevy front crossmember lines on a 71-72crossmember? If so, are the brake koses to calipers the same? What changes have to be made?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) Last edited by Primered_69; 12-04-2005 at 08:27 PM. |
![]() Join Date: Feb 2004
Re: Front Brake Line Question
I believe Matt67350 has done this. I do not think you will have any problem.
Designated A-hole!
I'll have to look, but off the top of my head they're not the same. The 71/2 lines run along the crossmember, but the 73+ run along that little crossmember below the radiator, with the proportioning valve mounted on the little crossmember. I don't remember the hose setup. If you need I'll try to take some pics tomorrow.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Yes you can use a 73 up line in a 72 and older crossmember. The hole is in the frame rail already just like the73 up trucks. You can find a rubber gromment to fit in the hole where the old flex line eneded and turned to hard line.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I agree.
Look at Matt's trucks. He uses 73-87 stuff just like you're asking about. Works great and looks good too. Nice factory bent lines look good.
