12-05-2005, 12:08 PM | #1 |
yes there are stupied questions
and here is one how do you get the damn black handle off of the light switch does it pull off or screw off thanks don't want to break it dave
12-05-2005, 12:18 PM | #2 |
Vintage Evil
Re: yes there are stupied questions
Seems to me that there is a release button on the back of the switch and the whole rod comes out. Been about 8 yrs since i have messed with it though.
12-05-2005, 12:20 PM | #3 |
yes there is a release button on the actual switch, push it down and the plastic handle and the rod slide right out.
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
12-05-2005, 12:50 PM | #4 |
ok i will try it tonight thanks guys
12-05-2005, 01:30 PM | #5 |
Watch out for your cornhole !
More detail...
Pull the lights switch on, then depress the button, and pull the knob and shaft out. You can't just push the button and pull.
12-05-2005, 01:33 PM | #6 |
Even more detail...
The button is on TOP of the switch.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-05-2005, 02:04 PM | #7 |
greenvilledave
GMC Pauls web-site has a nice write-up in his tips section. You will find it about half-way down the page. While you are there check out the great stuff you can get from one of the supporting vendors. http://www.gmcpauls.com/Tech%20Tips1.htm
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS Last edited by Hutch; 12-05-2005 at 02:05 PM. |
12-05-2005, 05:01 PM | #8 |
If is is still stuck consider using the cuttin' torch...works every time...
'67 C10 SWB Frame off (and smiling) |
12-05-2005, 05:15 PM | #9 |
12-05-2005, 07:52 PM | #10 |
its all about the +6 inches
Don't forget to disconnect the battery... your lights will be on.
12-05-2005, 08:35 PM | #11 |
Working on a Nova.
Here is a picture and I am pointing at the button.
12-05-2005, 09:51 PM | #12 | |
Son Of Gravel Man
I never pushed a button to get mine off. I did kinda a pull twist thing and it came off. Then when you unplug the wires to it the lights go out.
Daily driven 70 C10 longbed Its a work in progress Quote:
12-07-2005, 02:24 PM | #13 |
this is why i like to ask for help it's amazing how easy things are when you know what you are doing thanks alot dave
