12-05-2005, 02:09 PM | #1 |
Vintage Evil
front end question
is there any difference in the front ends part from a 70 to a 72? (except the spindles and drums) I have the opportunity to get a free front end off of a truck(cut off in front of the cab). I was mainly wanting it so i could clean up the crossmember and a arms and get them powder coated or painted without having my whole truck torn apart. Then i would use my spindles and disc off my current truck.
Any info would be great Thanks |
12-05-2005, 05:17 PM | #2 |
Vintage Evil
Re: front end question
no one knows of the a-arms and crossmemeber are the same?
12-05-2005, 05:50 PM | #3 |
member #16
I remember something about losing some turning radius when using 71-72 spindles with the older lower a arms. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-05-2005, 08:40 PM | #4 |
Just hang'n around
I put a '71 under a '68. I changed everything out. I think the Upper and Lowers are the same. Everything else is different including tie rods and ball joints.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
12-05-2005, 09:04 PM | #5 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-05-2005, 09:09 PM | #6 |
when i put dics up front on my '69, i took a complete front disc brake k-member from a '72 c-10 and swapped it out. the only thing that didn't line up was the front bolts holes on both side. all i had to do to fix this was to grind the hole in the frame out a little more to make them fit. i haven't had any porblems with it.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
12-05-2005, 08:49 PM | #7 |
agree with Steelaworkin, most likely your 70 has 5/8" LH thread outer tie rods. The 71 and up will require an 11/16" RH thread outer tie rods. You have options to get around this. I run 72 spindles on my 67 and if I lost any turning radius, I have not noticed it.
