Just here to help
![]() Join Date: Jan 2002
More brake help please
Hey guys,i have had some trouble with my brakes and i though i could fix it but i guess i was wrong.lol.first i will let you know what it has been doing.When i push on the pedal sometimes it is like i have no assist most of the time,even when i pump the brakes i just get power brakes some of the time,now for what i have done,i have a new booster that does work because when i pull the vac hose off of it i can hear it release the air inside,also i have put new pads on the front.any other ideas i can try to get them to work like they should?what else would you suggest?Thanx for any help i can get!!
![]() Join Date: Sep 2005
Re: More brake help please
i'd check the check vavle on the booster sounds like its sticking
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 12-05-2005 at 05:48 PM. |
Just here to help
where is that located at exactly...lol.
![]() Join Date: Nov 2004
Has your truck always had power brakes, or did you add them yourself.... is it possible you hooked up the the wrong vacuum port?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Just here to help
as far as i know it has allways had them,it didnt have an engine when i bought it but i got the vac hooked up to the back of the carb.
You could have a bad carb or bad booster? I'm guessing when you pull the hose with the engine running you can hear it constantly sucking air? Your saying your brakes work, but you have no power assist, right? maybe your new booster is bad?
A question? Did you pull the check valve out of the booster or just the hose? On mine when I pull the check valve it slaps real hard like a spring snapping. If I pull the hose no sound.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
Just here to help
i pulled the valve out and it poped,is there somewhere else i can try to attach the vac line to besides the carb?I have another carb i can try if i need to,thanx for all of the help so far.
the vac line for the power brakes should not be hooked to the carb but to the intake manifold you get more vac from the intake and makes the brakes work better
Just here to help
that may make a difference,i will have to see where i can put it at,it is the rpm performer edlebrock,any ideas?
Every vacuum booster I ever saw was in the back of the carb it is the same as the manifold. Do you have a vacuum gauge you could put on it to see if the hose is good. Most have a metal tube from the carb to just above the valve covers then change to rubber to the check valve. It is a very stiff hose so it won't collapse with the vacuum.
Just here to help
sorry i dont have a gauge,any other ways to check it?
No accurate way. Pull the hose and put your finger over it start the truck and see if it pulls on your finger then after it is running take your finger off and see if the engine stumbles or dies. If the hose collapses it will stay running smooth. this should be done when the engine is warmed up.
