its all about the +6 inches
The free 500/TH400
well, it isn't going to be totally free...he wants a hub cap I have.
![]() Here's the pics he sent me. Looks alot like the 425, I thought they were supposed to be diferant... |
HTe beast from the side...look at the tail shaft on that monster...guess it's time to chop the driveshaft down a bit huh?
It came out of that GMC burb you see to the right. i know one member wil recognise that burb...Wes, you reading this? |
I wonder how much spray paint it'll take to get this one running again...look real close at that oil pan, you see anything wrong with it?
#4 | |
Bloo
just keep spraying, youll eventually get the hole covered
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
i see a set of better flowing heads and manifolds for the 425 there...
good find... |
Half a bubble off!
That's a F**d pressure relief valve! I'd recognize one of those in any graveyard!
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
LOL @ ford relief valve!!!!!
You know, i was wondering about those heads. I guess a little more research is needed. Guran-dam-teed they are coming off too, regardless if I use them or not. LOL Blue! |
I knoe items I NEED off of it are exhaust manifolds, motor mounts, starter, (I think I see a cable hanging out from under there....just pray there is a starter on the other end) and I also need the alt.
The pullies and brackets along with the water pump will go in a package deal...The points dist. cap is probably a throw away aitme...or at least I'll just turn it into a oil pump primer tool. Heads and intake will come off and stored, and the short block will go directly into the scrap pile. |
72 Cheyenne
What are you doing with all those trucks? Give me a couple of em.
[b]I WISH!!!![/i]
These are pics from the engine owner...I won't pick it up for another 2 weeks. Friday the 26th is the first chance I'll get to go to Kalamzoo. (up in Michagan) |
Hmmm, don't know if aluminum paint would cover those holes. Might try black or blue, heard that was a little higher in particulates so it wouldn't take as much.
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
