Old 07-12-2002, 11:44 PM   #1
mikep
Used to have a truck
mikep's Avatar
Need help with rings
Ive got a set of sealed power file to fit moly faced (top ) rings that I am trying to figure out what to file them to. I would think .016" but the WORTHLESS tech sheet that came with the rings has got me confused on what the second ring gap should be. Can anyone tell me what they think of this tech sheet. I cant tell if they reccomend .010" , .012" or .016" for the second ring. It is cast iron.
No truck :-(
mikep is offline   Reply With Quote
Old 07-13-2002, 12:09 AM   #2
Super Chevy
Super Chevy's Avatar
id go .012 or .013
Super Chevy is offline   Reply With Quote
Old 07-13-2002, 12:17 AM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
It looks to me that it depends on the type of engine your building. If your building an engine for supercharged or nitrous then the recommended gaps get bigger. The second ring typically has a closer tolerance on end gap because it is exposed to less heat than the top ring. I would vote for the range of .010-.012". i think this is what their chart is trying to show.
Don
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 07-13-2002, 09:44 AM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
My guess...0.016 in. to 0.018 in. on the top and 0.010 in. to 0.012 in. on the bottom, assuming you are doing a street engine.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 07-13-2002, 12:54 PM   #5
flyin99
creator of kong
flyin99's Avatar
.018 top and .012 on second.you will be ok
flyin99 is offline   Reply With Quote
Old 07-13-2002, 12:58 PM   #6
mikep
mikep's Avatar
I went .016" on the top and .011" on the second. Seems tight to me as I have always run .014-.016 on the second but what the hell. Thats what the spec sheet seems to call for so I'll give it a stab. I usually use C&A but I went with sealed power this time.
No truck :-(
