Old 12-13-2005, 04:49 PM   #1
1978steven
1978steven's Avatar
What's it Worth?
I just looked at a 1982 Chevy 1/2 ton short bed 4X4 and was wondering what you guys thought it was worth?
It has a 350 engine, what looked like a recently replaced th350 (it was alot cleaner than the engine), t-case had a couple drops hanging off but no puddle on the ground, 1990 suburban front end, Maybe a 4 or 5 inch spring lift in the front, and block lift in the back. The 35 inch tires were pretty much toast, the paint has been redone, but done poorly. I couldn't find any rusted areas, just the normal slight surface rust on parts underneath it here and there. The entire truck needs some love getting the gaps and body lines to line up and look better, but all in all a very decent truck. The inside is all there but also needs some work. The used car lot wants $3500 for it. I would like to offer them about $1000 less than that, but I don't want to insult anyone. I did not take any pictures but I can take a few later if it will help.
Let me know what you all think and your help is always appreciated,
Steven
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 12-13-2005, 04:56 PM   #2
gn4u2c
gn4u2c's Avatar
Re: What's it Worth?
$2,000 buys that truck all day in my neighborhood
gn4u2c is offline   Reply With Quote
Old 12-13-2005, 05:48 PM   #3
1978steven
1978steven's Avatar
Here are a couple pictures I went and snapped real quick.
2004 Tahoe LT
1971 Chevy C10
Old 12-13-2005, 08:40 PM   #4
evan
evan's Avatar
That looks like some scary wiring under the dash.
Evan B.
evan is offline   Reply With Quote
Old 12-13-2005, 06:00 PM   #5
86 GMG
i believe i would give the 3,500.00 for it but like you if i can get it for less than do so i would qoute 2,000.00 and let them work you back up a little bit at a time. very nice looking truck from what the pics show.
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 12-13-2005, 06:17 PM   #6
84 400
Sb 400 club
84 400's Avatar
yeah 2,00 sounds good for that truck looks okay in the pics and the nice newer style grill. that looks like a nice project!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-13-2005, 08:34 PM   #7
1978steven
1978steven's Avatar
If I end up doing it I'll go low and see what happens. Thanks for the help everyone.
2004 Tahoe LT
1971 Chevy C10
Old 12-13-2005, 08:59 PM   #8
1978steven
1978steven's Avatar
It looks like car lot might have had some sort of problem with battery drain, they had some of the wiring pulled down from behind the dash. There is an amp wiring kit tucked up there and hanging next to the gas pedal. They put in a new battery to get it started. Trust me this truck will need a whole lot of work for it to be right, somebody did a bunch of "JERRY RIGGING" on her. I have never had a 4X4 before and I love this body style 4X4. It will be a project for sure!
2004 Tahoe LT
1971 Chevy C10
Old 12-14-2005, 10:33 AM   #9
nutsforchevys
nutsforchevys's Avatar
Is it just me or is there something odd looking about that dash? Isnt that a earlier model half a/c half non a/c??
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
Old 12-14-2005, 06:23 PM   #10
1985K10
1985K10's Avatar
Thats a 73-80 style dash pad, gauges and bezel look to be 81-87.
Looks like a good solid start! If theres no major problems id say $2000-3000 would be reasonable.
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 12-14-2005, 07:30 PM   #11
Jonboy
Slots go on anything!
make sure the wipers work. It has a later column, with the wipers on the column. They are suposed to have a switch on the dash in '82. Looks like it could be a cool project, if it can be had cheap enough.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-14-2005, 08:50 PM   #12
1978steven
1978steven's Avatar
I really need to look closer at this thing you guys are pointing out alot of stuff I didn't even notice. Thanks for the inputs so far.
2004 Tahoe LT
1971 Chevy C10
Old 12-14-2005, 09:00 PM   #13
1978steven
1978steven's Avatar
Here are a couple pictures of the t-case and tranny areas.
2004 Tahoe LT
1971 Chevy C10
Old 12-14-2005, 09:06 PM   #14
1978steven
1978steven's Avatar
Something I just noticed on that cross member it looks to have some sort of spacers between it and the frame. Should it be like that?
2004 Tahoe LT
1971 Chevy C10
Old 12-14-2005, 09:14 PM   #15
evan
evan's Avatar
Isn't the frame cracked just to the left of that???
Evan B.
Old 12-14-2005, 09:28 PM   #16
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Gages look like an 82 but the bezel is from an earlier year. 82 Bezel's aluminum trim is one peice. The one in the photo appears to have 3 sections. Also, I'm not exactly sure what was involved with wiring the wipers up to the columb wiper switch but I would take a look under the dash to see if the connections were made with good crimp connectors and not just taped together.
Other than that it looks to be a good start to a nice project. Around here it's not very easy to find early trucks that still have decent sheetmetal.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 12-14-2005, 09:33 PM   #17
1978steven
1978steven's Avatar
Not sure. I'll have to check into that too!
2004 Tahoe LT
1971 Chevy C10
Old 12-14-2005, 09:41 PM   #18
82 Silverado 4X
Genuine Chevrolet
I also think the crossmember spacers were placed below the frame to try to alter the drivetrain geometry.
Good Luck
George
Old 12-14-2005, 09:57 PM   #19
1978steven
1978steven's Avatar
I'm not sure about this one, the list seems to be growing and I don't want to get in over my head. Thanks for all the help so far. When I get a chance I'll take a better look at everything, and I'll have my list of things to look at with me.
2004 Tahoe LT
1971 Chevy C10
