What are you looking at?
reinstalling lower door trim
Well I went thru one of those touchless car washes the other day when the weather was nice and I'll be damned if the fan that drys the vehicles off when you are leaving didn't blow a couple of lower pieces of trim on the passenger side of my truck
1971 GMC LWB 2005 Honda Element 2007 Honda Fit ![]() |
Re: reinstalling lower door trim
This is like almost impossible. I've tried all sorts of ways with no simple solution. When I restore today, I eliminate the screw-bolt clip and use a spring loaded type. I also have used double sided 3M foam backed tape on lower trim with great results. If you can get a small wrench on the little bolt, but can't turn the wrench, I would rotate the clip from the outside and remove it. Then replace it with a spring loaded or 3M tape. IF your truck has nice paint, and the door is aligned really well, I would drill out the POS before I would remove the door. My .02!!
![]() Join Date: Jul 2004
I've cussed that problem several times. I would like to know how the factory did it. Marking the postion and removing the three hinge bolts on the bottom hinge has worked for me. It requires a very patient helper to hold the door while your're doing it so you don't wreck or scratch anything.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
where do you buy the spring loaded pieces that hold the trim on?
WTB this ad
I dropped my inner fenders and went in from the wheel well. Took forever but it worked. BTW the door will be closed for this process.
