Is there a way to remove the "home-job" type window tinting off of the inside of windows after yrs of baking it on and bubbling, etc.?
Bob |
Grab a razor blade and some glass cleaner. Use the the glass cleaner as a lubricant so you dont scratch the glass and start scrapin a corner. You may be able to peel from the corner, but it may leave a film behind that youll need to scrape off. Have fun, I did my rear window in about 15-20 minutes.
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
SKINNY TIRES RULE!
Razor BladeJust be careful not to scratch the glass. You can get plastic razor blades too but they don't work as well.
------------------ '69 K-5 Blazer - 350/TH350, 6" lift, 35" tires Bothell, WA
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
I *think* ammonia will loosen the adhesive. That is what the tint shop said they use to remove old tint.
SLICER AND DICIER
Get an edge started, and use a blow gun and it will blow it right off in one sheet. I have done this many times, then just clean what glue is left.
01 Tahoe 22's 2/4 drop and tv's ![]() 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
once you get the film off, you can use Acetone or Laquer Thinner to clean the remaining glue. The glue is the hardest part of removing tint. Be carefull with the acetone or thinner. Pour some on a rag, wipe the glue, let it sit and soak, pour more on rag, and then wipe. Repeat, repeat, repeat. If you can keep the glue damp, the easier it is to come off, and flip your rag pretty often because it will build up with all of the old glue and if you dont flip it or change it out often, you only put the glue on the rag back on the window.
hope this helps... ------------------ Keep On Truckin' Shane Athens, Alabama |
Sounds like good advise and fast responses too. Thanks a bunch.
Bob |
December 21, 2012
Just did this myself yesterday. Went got a razor scraper( handle with replaceable razors) cost 1.53 and just sprayed the window with windex and scraped it right off. Then went back and sprayed alot of windex on the window and scraped the glue off next. Used a new blade for each window. Took me about 10 min each window including wing windows.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
Old member
I did my two side windows about a month ago. I used simple green and the stuff just about came off by it's self. I also used a razor blade. SIMPLE GREEN
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 www.geocities.com/chevy71tpi/main.html] www.picturetrail.com/Andy4639]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Teufelhunden
i used razor blade, blow drier and some brake fluid on a rag to do mine
1971 K10 lwb fleetside 402 T350 205 |
![]() Join Date: Aug 2001
Brake fluid?!?! Yikes....be careful on those painted areas!
------------------ Prost68trk web page or btshaffer@wmconnect.com '68 short/wide, 402BB/TH400, '81 rear frame rails, F@rd 9" 31 spline, leaf springs moved inboard, shaved firewall, cab seam, wiper cowl, dash, hood ridge, chrome drivetrain. '97 Z-71 Ext-cab Driver West Fork, Arkansas IM - btshaffer (will soon change)
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
Never Done?
![]() Join Date: May 2000
I found out a few days ago that starting fluid removes the glue pretty well. Wish this post would've popped up a few days sooner though. Spent a few hours scrapin' on mine
![]() ------------------ - Adam L. Vogel White 68 GMC short, fleet, 350/TH350, 67-8 chevy grille, 5-lugs, front power disc brakes, power steering, a/c (not complete yet) |
