12-19-2005, 11:05 AM | #1 |
Ext to internal regulated alt wiring question
OK I've got all the goodies for a serpentine conversion coming and have read the faq's and googled but have one silly question.
Can I use the gauge in my dash for the #1 wire from the new alt ? I've seen it written up that you can wire to the idiot light or use a 35 -100 ohm 3 watt or larger resistor, then in another thread someone mentioned you could use the gauge in clusters so equipped. My multimeter has decided to croak so unless santa brings me a new one I can't just measure the resistance of the gauge... and even then i'd feel better knowing others have used theirs successfully for extended periods. I've got some 75 ohm 5 watt resistors but am unsure how well they'll hold up in an engine compartment even shrink tubed, tie wrapped and othewise protected.
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page |
12-19-2005, 11:42 AM | #2 |
User #12137
Re: Ext to internal regulated alt wiring question
go here and read
http://www.madelectrical.com/electri...hreewire.shtml |
12-19-2005, 02:15 PM | #3 |
http://67-72chevytrucks.com/vboard/s...d.php?t=119379 to wire the new alt i just switched to an int volt reg wonders it does
12-19-2005, 04:43 PM | #4 |
I'm guessing since you have a serp setup and are talking about wiring an idiot light or resistor to your alt that you have a CSxxx type alt? If so, no the gauge will not surfice replacing an idiot light or resistor. There needs to be enough resistance to cut the exciting voltage down to the alt to keep from frying the exciter circuit.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
