Old 12-21-2005, 03:53 PM   #1
olblue81
olblue81's Avatar
Adding A/C
Wanting feedback from people who've added A/C to their truck. My 81 Sierra Classic came from the factory with cruise as the only option. I added a tilt column years ago, but now I want cold air. I was planning on scrounging brackets, ducts, vents, controls and everything from a wreck and buying parts store condenser and compressor. That way everything looked like the General did it.
But now I'm wondering if an aftermarket system wouldn't be better so there is no doghouse under the hood for the evaporator. Is there an aftermarket kit that uses the factory dash controls? That is one thing I won't deviate from. It's got to use the factory dash controls.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 12-21-2005, 03:57 PM   #2
yank
yank's Avatar
Re: Adding A/C
Look at vintage air. They have a number of kits avaliable.
70 C/10 SWB
Go ahead chance it........Columbus did!!!
Steve (Chitlin) Bacon
My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/
yank is offline   Reply With Quote
Old 12-21-2005, 04:09 PM   #3
beaterC10
Re: Adding A/C
Aftermarket is prolly the easiest to retrofit A/C. The firewall openings are different between a factory A/C cab and a non A/C cab.
beaterC10 is offline   Reply With Quote
Old 12-21-2005, 05:18 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Adding A/C
I have not done it, but several of the folks here on the board have reported that they successfully cut their firewall to accept the factory A/C setup.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-21-2005, 06:26 PM   #5
olblue81
olblue81's Avatar
Re: Adding A/C
Slonaker
I know about the opening - I was told to make a cardboard tracing of the opening in the donor truck and to use it to make the opening bigger in the other. I am under the impression that the opening just has to be made bigger. I don't know, maybe some of the original has to be closed off?
I was just at the Vintage Air site and it shows the system using the original controls. I'll check that out more.
Stu-
Old 12-22-2005, 03:20 AM   #6
apstguy
LED King
apstguy's Avatar
Re: Adding A/C
I'll tell you, Vintage air will probably be the most cost effective way to add a/c. Just to get my a/c to r134a was $300+ (including compressor) and that is if you have all the equiptment (vacuum pump, gauges, & lines).
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 12-22-2005, 11:14 AM   #7
Slonaker
Slonaker's Avatar
Re: Adding A/C
A friend of mine used to work at Vintage Air. he says the kit is of good quality.
Slonaker
Stock '01 Silverado
Old 12-22-2005, 11:53 AM   #8
PHOENIX
Re: Adding A/C
When I got my truck it had an aftermarket kit in it.
It worked well, but I had problems and didn't like the design.
I was from some company in Texas.
I ripped it all out and have no A/C in Phoenix, its hot.
I vote factory a/c!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
