PROJECT 7DEUCE
![]() Join Date: Dec 2002
Need cab squared...
For those of you who have taken cabs off and on what is the best to use for reference when you are lineing the cab back up to be square... Any help would be great....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Fabricate till you "puke"
Re: Need cab squared...
I try to even up the distance from the bottom edge (lip)of the rocker side to side, in both front & rear of the cab to start with. when you start hanging front tin, the hood/fenders will tell the story pretty well on alignment. You may need to play with the pcs a little to straighten em up, but its not too bad. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
PROJECT 7DEUCE
Thanks crazy I cannot wait to get this truck back together!!!!!
Hang in & hang on! The resto stuff goes d@mn slow...... the end results will be worth the effort tho.....
Saving 1 truck at a time!
Take some notes on the height of the cab from the mounts in each corner. It is easy to torque them down unevenly. One end has the big square washer that, it left out, will tilt the cab and throw off the front fender gap. Watch the core support mounts too since they are another big source of front fender gaps! This is the part of assembly that I actually really enjoy...adjusting the front sheet metal and doors! I know...I'm sick!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Stllookin - When it's time to do mine, I'll give you a call.
Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#7 | |
![]() Join Date: Nov 2005
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
Out of the carpool lane.
Thanks Crazy, I'll be putting my cab on soon too! Thought it was going to be tomorrow, but found out I have to go in to work.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
stllookn- Where does this big square washer you mention go?
I am not recalling it, and might could use it. Thanks
Good Judgment comes from experience. Most experience comes from bad judgment. |
I don't recall a big square washer when I took my cab off!?!
Yep, I'll give you a call too!
I would suggest assembling the cab mounts and radiator support mounts but don't tighten all the mount bolts down until the nose including the front bumper is installed. You will see why when you get there.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
![]() Join Date: Jul 2004
The square washers are for the front cab mounts, my last new set came with 2 for each front cab mount (4 total), but they are optional, the mount will work fine without it. They may be needed to get your fender/door gap right.
Some trial and error will likely be needed to shim everything square.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
PROJECT 7DEUCE
Heres a pic of the square washers...
Rokcrln...we've seen your "art work"...you get no sympathy from us...LOL! Can't wait to see the progress...it is an inspiration to the rest of us metal "butchers"!
