Old 12-22-2005, 04:52 PM   #1
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Industrial 327
I was wondering if anybodys ever heard of an industrial engine from Chevrolet. My old man's got a 1970 Massey Ferguson Combine that came from the factory with a 1969 small block 327. If i recall right this thing used to cruise through the field at about 6,000 RPM with no problem at all. Has anybody ever heard of anything like this? and if so what do you think one of these engines would be worth. I'm thinking about throwing 200 bucks his way for the motor and it still runs fine.
WRMZ71 is offline   Reply With Quote
Old 12-22-2005, 05:15 PM   #2
beaterC10
Re: Industrial 327
I've heard of flathead Ford industrial engines, big block Chevy and Ford engines, so an industrial SBC would make sense. Who knew Massey tractors were a source of 327s
beaterC10 is offline   Reply With Quote
Old 12-22-2005, 05:19 PM   #3
StingRay
StingRay's Avatar
Re: Industrial 327
Some years ago a local board member Jesse67c10 used one with vortec heads on his truck. I think it worked great for him. The cam and heads are propably not up to any big performance but the shortblocks as I understand it are high nickle and they have steel cranks.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 12-22-2005, 05:21 PM   #4
1969 C/K CST
A.K.A- Crummy
1969 C/K CST's Avatar
Re: Industrial 327
Massey used alot of GM parts. May not hurt to take a look at some just sitting around.
2003 Silverado Z71 Are fishermen all liars?
1969 C/K CST is offline   Reply With Quote
Old 12-22-2005, 05:32 PM   #5
matt67350
matt67350's Avatar
Re: Industrial 327
Valves and cam will be small.
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 12-22-2005, 05:40 PM   #6
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Re: Industrial 327
Operational rpm on the Massey combines is governed at about 3200 rpm if I remember correctly. It just sounded like 6000, because of the 8 million chains, sprockets, gears and other devices doing 50 things at once! I spent many hours with a Massey 510 combine, a 1970? Factory Chevy 327 power. Supposedly, these do have a steel crank (never offered on automobile 327's) and 4 bolt mains. The heads are pitiful, tiny intake and exhaust valves. Slap some vortecs on and have fun!
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 12-22-2005, 05:54 PM   #7
crazy longhorn
Fabricate till you "puke"
Re: Industrial 327
68 was sposta be the last yr on the LJ 327.....me thinks there were lots of pcs left over, & the 69 yr got a few! the steel cranks WERE availble in the automotive engines, but VERY SCARCE! There is no such thing as a 4 bolt 327.....in auto stuff anyway. if you can show a 4 bolt 327 in industrial, or ag equipment, i would like to see it things tend to get different when you go industrial , or ag. Heck, I think you should pack that 327 up & send it to me.....Ill send you a 350 /4 bolt + stroker crank for a replacement to rebuild L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-22-2005, 06:28 PM   #8
Chris H
Chris H's Avatar
Re: Industrial 327
I might be mistaken about the LG327 steel cranks? Maybe it was the 4 bolt 327 that I was thinking?
I have been told that this spring I will be taking the Massey apart... and this time I dont have to put it back together!! I have waited for about 10 years to see if this engine does have the mythical steel crank and 4 bolt block...
If it does, I am going to take pictures and list casting numbers, etc.
If it doesn't, I am going to hide it in the corner of the garage and pretend I never saw it before
Chris H
72 C30 133"
69 C10 short fleet
71 ElCamino
2006 K1500 RCSB
Old 12-22-2005, 06:03 PM   #9
hoser
Re: Industrial 327
I have been told by older mechanics over the years that "industrial engines" GM and others, have thicker blocks, some have high nickel, blocks, forged cranks and the better rods timing chains etc. same goes with the engines they put in motor homes and larger GVW trucks.
hoser is offline   Reply With Quote
Old 12-22-2005, 06:14 PM   #10
crazy longhorn
Re: Industrial 327
Shhhhhh! dont tell too many guys that, or you wont get a good deal cheap L Truely, on the high nickle blocks(10/20) on the front face of the block , under the chain cover .....I have 2 or 3, 2 bolt(350) blocks, & a 4 bolt block(all truck stuff).And while the 350 steel cranks are hard to come by, a steel crank in a LJ 327 is really rare L
Old 12-22-2005, 07:06 PM   #11
84 PUMPKIN
Re: Industrial 327
I purchased several (five or six) of these 327 "industrial" engines in the late eighties from a guy in Iowa. They came out of Massey-Ferguson combines that he was cutting up for scrap. The blocks had a high nickel content, large journal 327 steel crankshafts, and 4 bolt mains. Yes. A 327 with 4 bolt mains. I've never seen a 327 4 bolt main engine in a Chevrolet car or truck so this might have been a special order thing for Massey-Ferguson. I still have one of the engines and it's currently installed in my '34 Chevrolet 3 window coupe.
84 PUMPKIN is offline   Reply With Quote
Old 12-22-2005, 07:23 PM   #12
67-72chevyman
Re: Industrial 327
Chevy did put steel cranks in some car motors, my buddy fell into a heck of a good deal, he got a I think it was either a 300 or 325 horse, it was a block made somewhere between 64 and 66 cant recall, but it had a steel crank, and camel hump heads, he only paid 200 dollars.
67-72chevyman is offline   Reply With Quote
Old 12-22-2005, 08:01 PM   #13
crazy longhorn
Re: Industrial 327
62-66 were all steel cranks (sj 327).....67 was a weird yr, you could have cast or forged on the cranks that yr. 68 went LJ, & most were cast cranks, but a few were steel. I have heard the 4 bolt 327 story many times , & said .......in auto stuff we didnt see em(I built a couple tho). industrial is weird stuff......try a steel crank in a 455 Olds(68-69-70) on the hypo stuff. Damn rare bird, but I had a 943 forging from a 2 brl 455(68, red block) L
Old 12-22-2005, 10:13 PM   #14
67-72chevyman
Re: Industrial 327
Heres something else for you, someone I know rebuilt a early chevy V8 I'm assuming its a 265 or 283 in high school he didn't know much on it, but he said it had a steel crank. Also any of you guys know if they ever made a 400 industrial engine?
Old 12-22-2005, 10:30 PM   #15
WRMZ71
WRMZ71's Avatar
Re: Industrial 327
Yep its a 510 for those of you who had said. I couldn't quite remember for sure but when you said that, it clicked right in my head. I have an older brother who tells me this thing has a steel crank in it and him and me have been chomping at the bits for the last 5 - 10 years to get our hands on this motor. Dad always said he would find a new head for it. I actually got the go ahead one time that i could have it so i started pulling radiator hoses and such and then he come out screaming "leave it alone!!" I just found a new head for that combine and then found you a 350 out of a grain truck. I still have that 350 and it came with a steel crank but it burned up when the HEI driveshaft I put in there did not match up with the oil pump shaft and after 3 days she was dead. Still kicking myself on that one. 3200 RPM probably does sound right but one time I remember looking at the tach while it was running through the field and it was saying somewheres around 6000 RPM. Dumb tach was probably broke. That thing was loud as hell as it only had some straight pipe headers for exhaust. Anybody got about 2500 bucks to spare so I can put that Holley Pro Fuel injection on this thing when i pull it out?
Old 12-23-2005, 02:43 AM   #16
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: Industrial 327
all I know for "extras" is that they came with steel cranks - Chris H is right. I got my steel 350 crank out of a combine...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 12-23-2005, 08:28 PM   #17
67sss
67sss's Avatar
Re: Industrial 327
what about the early 60's(1 or 2) corvette 327? didn't it come as a 4 bolt w/ steel crank? My 327 WAS a 13:1 and now is a 10:1 and believe it's a 62'. Any more info about these 327's would be great.
67sss is offline   Reply With Quote
