Old 12-23-2005, 09:53 PM   #1
3100 special
Street Rod Dreamin'
3100 special's Avatar
Location: Work:Batam, Indonesia/ Home:League City, Texas
Unhappy Help! I haven't seen this question before...
OK folks, I need some help. The rims I have on the panel have locking nuts. I know I hung onto the key for years but, I’ll be danged if I can find it anywhere. I ended up pulling the whole front end today, tires and all for my new IFS but… I’ve gotta get those rims off so I can put them up for sale.
I tried taping an impact socket on...no bite. I even made a couple of tries clamping a set of vise grips on a tapping with a hammer…no good. I didn’t spend a whole lot of time on it because I wanted to get other things done today.
I’ll give anything a whirl short of applying a torch. Oh by the way, if the photo is not good enough, it's the type that the notches are down around the bottom edge, not the grooved top.
Thanks!
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2007 GMC Sierra 4X4
"I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776
3100 special is offline   Reply With Quote
Old 12-23-2005, 09:57 PM   #2
screamin_c102
screamin_c102's Avatar
Re: Help! I haven't seen this question before...
Go to a tire shop, they usually have a tool for removing locking nuts.
screamin_c102 is offline   Reply With Quote
Old 12-23-2005, 09:59 PM   #3
3100 special
Street Rod Dreamin'
Originally Posted by screamin_c10
Go to a ttire shop, they usually have a tool for removing locking nuts.
I might have to. It'll be a pain in the rectum though...I'll have to load my whole front end up in the back of the truck!
It might come to that though..
Thanks!
2004 GMC Yukon
2007 GMC Sierra 4X4
Old 12-24-2005, 01:28 AM   #4
70short/step
70short/step's Avatar
I have used a socket before. One that almost fit over the lug but not quite. Beat it on with a BFH and that usally worked. Your local auto parts store should sell a lug nut splitter that might work depending on the rim. Also if you have a welder weld a big nut to the lug and then use that with an impact to remove. Good Luck!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 12-24-2005, 01:48 AM   #5
veedublu
I would go with the socket idea... but DON'T use an impact socket, they are usually 6-point. You want a 12-point socket, hopefully 1/2" drive (that way you have a bigger hole to slide a punch through for getting the nut out of the socket once it's removed).
Good luck.
1976 K20 my dad bought new - longbed stepside, just turned 50k miles
veedublu is offline   Reply With Quote
Old 12-24-2005, 01:24 AM   #6
bs25j
bs25j's Avatar
i work at a tire shop..but i cant tell what kind of lock it is from the pics..certain locks can be removed pretty easy by hammering an old junk key on to the lock and it will usually bite. but there are some that are a lot more difficult..
bs25j is offline   Reply With Quote
Old 12-24-2005, 02:15 AM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
weld a nut on the lock and turn it off with a socket
Old 12-24-2005, 03:58 AM   #8
bigbuc
Certified Pud Puller
bigbuc's Avatar
look man all the big tool companies like MAC and snap-on sell a socet set just for removing stripped bolts and wheel locks get a set or even one that is the right size and i promise u wont be dissatisfied
1997 Silverado extended cab- mpfi conversion, 22" kmc's
1983 C10- some assembly required
99.5 F250 Super Duty 7.3 5" straight pipe, wicked wheel, ts tuner, ccv mod, 4" lift 315/75/16s
bigbuc is offline   Reply With Quote
Old 12-24-2005, 11:16 AM   #9
3100 special
Street Rod Dreamin'
Thanks guys! I hunting for a tool truck today. Sounds like it might be the easiest idea.
Let ya know...
2004 GMC Yukon
2007 GMC Sierra 4X4
Old 12-26-2005, 10:39 AM   #10
FormerMember
Can you get a nut splitter on there?
FormerMember is offline   Reply With Quote
Old 12-26-2005, 11:05 AM   #11
3100 special
Street Rod Dreamin'
Maybe. I don't have one so, it's hard to tell until I lay one on there. After pricing extractors this morning (roughly 70 bucks), I'm going to try the 12 point socket route.
I've got other things I'd rather spend my money on!
2004 GMC Yukon
2007 GMC Sierra 4X4
Old 12-26-2005, 11:07 AM   #12
b454rat
LIke bigbuc said, there are tools out there JUST for removing lugnut locks. Buddy owns a junkyard, and he has a set of them, saves alot of time, and sometimes rims. If you get heat on them and aren't careful, just ruined a set of rims.....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-26-2005, 11:19 AM   #13
FormerMember
Nut splitter should be cheaper.
Do you have a welder?
Old 12-26-2005, 07:05 PM   #14
3100 special
Street Rod Dreamin'
Got the solution at HF today, just didn't get one big enough... today was not my day. 18 bucks for the set. I'll hang onto these, no telling when then might come in handy. I'll pick up the next size up.
Tomorrow's another day though!
2004 GMC Yukon
2007 GMC Sierra 4X4
Old 12-29-2005, 08:51 PM   #15
3100 special
Street Rod Dreamin'
They're off! I found another set of nut extractors. The 3/4 fit it just right. A ratchet with a cheater pipe and no problems.
I had to buy a set of five to get the one I wanted...22 bucks.
Well spent though.
Thanks for all of the suggestions!
2004 GMC Yukon
2007 GMC Sierra 4X4
