Old 12-23-2005, 10:51 PM   #1
Big Bad 1972 Blazer
Big Bad 1972 Blazer's Avatar
Rear shackle ?..72 vs 73 differances
Hey all. Quick easy question for somebody that knows...
What is the differance between the rear shackle on the rear leaf spring on a 72 versus a 73-87 4x4? Assume both trucks are 1/2 tons.
Long story short, a freind of a friend of a friend is parting out his '74 and he's got a shackle flip kit on it. If I remember correctly, it's not a direct bolt in, but it's close, so with a little fab work I could score a sweet flip kit cheap for my '72.
Big Bad 1972 Blazer is offline   Reply With Quote
Old 12-24-2005, 11:23 AM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Rear shackle ?..72 vs 73 differances
if you are willing to do some fab work then it shouldnt be a problem, but i am pretty sure they are a close fit.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-24-2005, 11:30 AM   #3
Prerunner1982
you could also contact Off Road Design as they have a shackle flip for both generations.. http://www.offroaddesign.com/catalog/shacklekit.htm
Old 12-26-2005, 04:14 AM   #4
68Shorty4x
The rear brackets will not have the correct offset. They will be about 3/4 inch wider on each side. A cheap alternative is to use the front spring hanger from the rear of a 2 wheel drive. With a little drilling they work great, and you can give your shackle any angle you want.
68Shorty4x is offline   Reply With Quote
