Old 12-23-2005, 11:59 PM   #1
slammd72
slammd72's Avatar
1ton lca question!
what wears on the one ton lca? is it the nut or the shaft? or are they designed to not wear, and never get replaced?
slammd72 is offline   Reply With Quote
Old 12-26-2005, 11:22 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: 1ton lca question!
Both pcs wear, it just depends on how much wear as to replacement parts used. I have gotten lucky enough to replace bushings only & tighten up an old truck for a while. If you have lots of slop in the arms, you would be best to change shafts & bushings tho.... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-26-2005, 04:24 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by slammd72
..... or are they designed to not wear, and never get replaced?
Maybe if they were made of kryptonite? This is GM truck parts we are taking about. It's going to wear out sooner or later...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
