Old 12-25-2005, 09:19 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Lowering the rear with coils- track bar?
I am planning to drop the rear of my 70' with either 4" or 5" coils. How much will this shift the rear of my truck?. I'm assuming the 5" will shift it to where I need a track bar. Correct?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-25-2005, 09:41 PM   #2
cableguy0
Re: Lowering the rear with coils- track bar?
thats definately enough that you will need and adjustable track bar
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-26-2005, 12:44 AM   #3
SCOTI
SCOTI's Avatar
Over 5" will require adjusting the length of the track bar which can be accomplished different ways. Two of those ways are cutting the stock bar to the desired length required to center the rear @ the new lowered ride height or spending the money for an adjustable bar.
The adjustable bar is easier & modifying the stock bar is less money. Which do you have more of: time or money?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-26-2005, 09:18 AM   #4
mike nutt
69fatmotor
mike nutt's Avatar
70c10, heres a picture of the rear of my '69c/10 with 6" springs and an adjustable super track bar from ECE. the longer bar greatly reduces side to side movement during suspension travel.
mike nutt is offline   Reply With Quote
Old 12-26-2005, 09:37 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Thanks guys!
Jim
Old 12-27-2005, 02:35 PM   #6
70c10
67-72 Addict!
70c10's Avatar
After reading this again, Scoti says "over" 5" needs one and mike nutt has a 6" drop. Is it possible 5" may work without the adjustable bar?.
Jim
Old 12-27-2005, 02:49 PM   #7
cableguy0
going 5 your definately going to have the rear shifted to one side screwing up all the suspension geometry.
Old 12-27-2005, 07:57 PM   #8
SCOTI
SCOTI's Avatar
The more you lower it, the more the rear shifts over to the pass side.
I know you can get away w/a 5" drop w/o an adjustable bar (or longer, super track bar) because my buddy was too cheap to buy one when we did his 65. Whether it works or not on your combo is directly related to how wide the wheel/tire combo is & what kind of backspacing you have.
To make sure the tires won't rub, use an adjustable bar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
