Straight jacket required
C Notches
Could ya'll give me some pics of your weld in C notches??
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
Needs a Big Block
Re: C Notches
Sorry it sucks it just a peice or round tubing welded in and I dont have any better pics
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
Re: C Notches
No--that's exactly what I am putting in--could you take a couple more at different angles?? Thats perfect!!! Also, is it installed right between the cross bars. Mine is all torn down for alterations and not sure where to put in exactly.
Re: C Notches
Off topic question how low can you go before needing to notch the frame?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO Last edited by 76bonanza; 12-29-2005 at 03:48 PM. |
Re: C Notches
Most would perfer 3"between the axel and frame for travel. I am going to try running around with 2" to the bump stop and 3" to the frame. I currently has 4" to the frame and 3" to the bump stop. You can feel when you bottom out but I dont care. It's not often either. My truck is leaf so I would perfer to box the entire frame from hanger to hanger if I was to install a notch because of the stress that would be in the notched area. But my frame is Epoxy primed and gloss black. I have no plans to cut or box it.
For a coil truck all the stress is up front so boxing the entire rear of the frame is not necessary.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 12-29-2005 at 08:32 PM. |
Re: C Notches
I will be running on firestone 2600 bags---with bump stops.
Re: C Notches
Ttt
