01-01-2006, 12:39 PM | #1 |
67-72 QUESTIONS (Rockwell T-221 swap+tranny Q)
Hello,
First of all, I'd like to know what my 68 GMC has for a transmission. It has numbers on the top cover but they don't say the make of the tranny, just GM numbers. Reverse is next to 4th gear, if that helps. Second, I am thinking of a transfer case swap. I read in a previous Rockwell t-case thread that a Sm465 with a Rockwell tagging along is the same length as a 465 with an NP205. But another thread that I started said I had to move the t-case crossmember back and re-do the driveshafts. So heres my other Q: if I could get a complete parts-truck with a NP 205, could I bolt the t-case and driveshafts right in, move the crossmember back, and be all set? Are the trannys the same? Thank you for responces. Last edited by FUNMUDDER; 01-01-2006 at 11:36 PM. |
01-01-2006, 06:04 PM | #2 |
Re: Few questions (rockwell T-221 swap and tranny)
Ttt
01-02-2006, 02:44 AM | #3 |
when I converted mine (although the project has since frozen) I had to move the crossmember back perhaps 1.5" iirc. I might have been able to get away with the stock 2 pc driveshaft if i shoved the splines all the way into each other, but you'd need the front shaft lengthened. I'm guessing my thread was one of the ones you found.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
01-02-2006, 03:58 PM | #4 |
Before you ask where it went..............I removed the duplicate thread. Please don't make duplicates, it's in the rules.
01-02-2006, 10:07 PM | #5 |
Sorry about that. Won't happen again.
01-03-2006, 08:01 AM | #6 |
Jake:
If the tranny has the casting #: 3901127 it's an SM465, and it's a Muncie. Not so much a make, as a town where GM had a transmission plant. [Muncie, Indiana; Saganaw, Michigan].
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 01-03-2006 at 08:05 AM. |
