Old 01-03-2006, 01:52 AM   #1
71-longbed
Its Magically Delicious
71-longbed's Avatar
the 71 died on me ..
1 block away from my place .... ive probaly driven 150 miles in the last couple days .. i was almost home and i came around the corner and the engine lugged down and died.... hit the key and nothing ..
had a friend jump it .. fired right up ... gonna swap alt's tomorrow ... hope that fixes the problem ... could it maybe the be the voltage reg ?
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 01-03-2006, 01:58 AM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: the 71 died on me ..
i love your avatar thats
sorry about your truck
tnblazerk5 is offline   Reply With Quote
Old 01-03-2006, 07:40 AM   #3
Yes it could be your regulator, but check the alternator first. I know way back, we always use to put on a new regulator when we swapped alternators. Why?..I don't really know, probably some old wives tale about them needing to match up.
Old 01-03-2006, 10:02 AM   #4
truckdude239
truckdude239's Avatar
if it is the alternator and you are still on an ext. voltage regulator i'd remond switch in to an internal. my ext volt reg went bad and i got 3 of them from the parts store and all of them didn't work right so i sent 38.88 on an int reg alternator of an 83 chevy k-10 4x4 with 305 took about 30 mins heres the link http://67-72chevytrucks.com/vboard/s...d.php?t=119379 just follow it is is alsome
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-03-2006, 11:30 AM   #5
All newer vehicles get a new reg. when alternator is replaced,so...
Check connections first.
Old 01-03-2006, 11:35 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
What kind of ignition system? Points/Condenser or HEI?
Reason I ask is I had a problem when the wire inside the distributor to the pickup module, had a break that only showed up when I let off of the gas, letting the "breaker" plate move as the vacuum level changed (increased). It may be clutching at straws, but I can't be the only one who ever has had that problem.
Member Nr. 2770
Old 01-03-2006, 11:37 AM   #7
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
That's where I'd start, battery terminals and wiring at the alt.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 01-03-2006, 01:32 PM   #8
71-longbed
71-longbed's Avatar
i swapped alt's this morning ... and it fired right up and idled ok ....all seems well ... thanks for all the posts guys ..peace
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 01-15-2006, 11:19 AM   #9
71-longbed
71-longbed's Avatar
had the old alt. tested for $hits and Jiggles ... failed across the board ....
whats the best way to test a voltage regulator on the bench .. i have a used spare one.. and i'd like to know if its good ... anyone done this before
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
