One quick question are the dimension for the turbo 350 identical to those of the turbo 400? Not exact dimension but in reference to length of the transmission body. Please just one question all I need is one answer really.
FAMILY MAN 77 CHEVY LB 4X4 ![]() 78 GMC LB 4X4 ![]() 77 GMC FLATBED 502 CADDY BB. ![]() 85 CHEVY BLAZER (wrecked) ![]() 86 CHEVY LB 2WD 77,000 ORIGINAL MILES ![]() 86 RX7 "SOLD" 88 RX7 "SOLD" 88 SUPRA "SCRAPPED" DIVORCE SUCKS 2003 HONDA CBR 600 F4I ![]() |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Turbo???
the case length on both are not the same, th400 being roughly 3" longer. Overall length depends on the length of the tailhousing, so one could be longer than the other.
In the sense of your project, not only is the TH400 longer, the output shaft is different also and will not mate to a TH350 version transfercase.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Re: Turbo???
ok thanks so much captkaos That helps so I don't go out and look for a turbo 400 tranny.
Re: Turbo???
No problem. You can go look for one, just make sure it has a transfercase attached to it.
Re: Turbo???
But if it had a transfer case it wouldn't fit the low hump. Would it???
Re: Turbo???
If you are having problems with the transmission t-case hitting the body there is no way anything will go under there without hitting if it has a t-case attached.
