Old 07-15-2002, 10:24 PM   #1
AK70SWB
Question drag launch set up
any one got a good suspension set up for a drag launch but streetable? i'm not there yet but have heard that once your get up there in HP that wheel spin becomes a big problem. anyway, any help would be great!!
the sun even shines on a dogs a$$ some days!!!
AK70SWB is offline   Reply With Quote
Old 07-15-2002, 10:37 PM   #2
SCOTI
SCOTI's Avatar
A couple of guys on here have suggested removing the stock coils & replacing them w/coilovers behind the trailing arms, then use airbags to pre-load the suspension for best launch. Definitely go w/urethane trailing arm bushings & maybe a solid sway-bar in back to limit axle twist in relation to the frame along with a good front end alignment & a hollow sway bar(or none @ all) up front to reduce weight.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-15-2002, 11:03 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Removing or just disconecting the front bar also lets the front raise a little faster and a little further. The weight gain in getting rid of it is not noticable, and if it is a street/race vehicle, you'll want it there to hook back up...esp if running a rear bar too.
Old 07-21-2002, 11:01 PM   #4
AK70SWB
THANKS FOR ALL THE HELP
ANDY
Old 07-21-2002, 11:04 PM   #5
Longhorn Man
The coil spring set up is actually a d@mn good one. Those real long ladder bars act as traction bars, that's why wheel hop is never an issue...onless your lowered 5 inches and haven't corrected the shock angle.
