Old 01-05-2006, 11:36 PM   #1
OleBlue69
OleBlue69's Avatar
Adding power to my powerless brakes
First off, thought I would introduce myself. My name's Justin, I have a 69 SWB fleetside, rusted up real nice. So far all I have done to my truck is work on the drivetrain - I built a 383 stroker for it and put in a M-20 muncie. I'm only 21, so the funds are pretty limited and I haven't been able to do much cosmetic-wise to it yet. I been visiting the forums for a couple of weeks and have been very impressed with the knowledge present and number of members.
There is a 71 that has power brakes that I am planning on putting in my truck. I know that I will need to take out the vacuum booster and the master cylinder obviously. I would appreciate tips from anyone who has done this before. How long do you think it will take - a day job maybe?
Thanks!
OleBlue69 is offline   Reply With Quote
Old 01-05-2006, 11:43 PM   #2
truckdude239
truckdude239's Avatar
Re: Adding power to my powerless brakes
shouldn't be that bad couple hours at the most
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-06-2006, 08:27 AM   #3
neonlarry
neonlarry's Avatar
You do not need the master leave yours on and hooked up, just pull it out enough to fit the booster and bracket in between. You will need the booster, bracket, linkage and probably take the vacuum fitting from the manifold unless you already have one.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-06-2006, 11:06 AM   #4
Putter
More Cowbell....
Putter's Avatar
Yepper. Whar Neonlarry said.
Just unbolt the master from the firewall (leaving the lines connected) and gently ease it away from the firewall....careful not to kink any lines down by the frame.
Slip the booster & bracket in between and button it back up!
Install the vacuum hose for the booster.
Change the rod that runs from the pedal to the booster and violla...
POWER BRAKES.
Watch your head, though...I almost smacked mine on the windshield when I changed over!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 01-06-2006, 02:21 PM   #5
mrein3
mrein3's Avatar
Originally Posted by Putter
...stuff deleted...
...stuff deleted...
Putter said it but nobody pointed it out as far as what you need to grab off the donor -
Make sure you grab the rod that connects the pedal to the back of the booster. I believe it is a different length on power verses manual trucks.
Well I guess neonlarry said linkage.
Just make sure you grab that piece too.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-07-2006, 05:04 AM   #6
Bob B.
Be careful! '67 to '70 trucks use Bendix boosters, and the master cylinders have a deep hole in the piston for the booster pushrod. '71 and '72 trucks use a Delco booster. Some Delco boosters have a shorter pushrod, and the master cylinder has a very shallow hole for the pushrod. If you use one of these Delco boosters with one of the earlier master cylinders, you could end up with too much play between the booster pushrod and the master cylinder piston, which could give you a very low or no brakes at all.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 01-06-2006, 01:07 PM   #7
farside847
farside847's Avatar
Here is the writeup on my install....
http://67-72chevytrucks.com/vboard/s...d.php?t=163387
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 01-07-2006, 05:12 AM   #8
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi! You're doing the best upgrade for the money there is in my opinion. The hardest part of the mod is adjusting the stupid brake light switch.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-07-2006, 11:21 AM   #9
OleBlue69
OleBlue69's Avatar
Thanks for all the replies guys! Krue, what do you mean about adjusting the brake light and how do you do that? Thanks again!
Nice thread farside847!!!
Old 01-07-2006, 11:30 AM   #10
Novaguy73
Novaguy73's Avatar
Just remember what ever you do...make sure you add blinker fluid!!
J/K Where did you get your booster and parts at? Can you get them through autozone??
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere...
-72' C10 350 Auto 12 bolt, runs 19's?? drives to work!
Novaguy73 is offline   Reply With Quote
Old 01-07-2006, 03:08 PM   #11
OleBlue69
OleBlue69's Avatar
Novaguy73 - I'm swapping all my stuff off of a 71. I do know that you can get the master cylinder from autozone, along with the blinker fluid, but not sure what else. Thanks.
