01-08-2006, 06:20 PM | #1 |
Power steering with long water pump?
Does anyone have any pics of how the power steering brackets are mounted when using a long water pump? I have the brackets but can't figure out how they mount.
01-08-2006, 10:34 PM | #2 |
Re: Power steering with long water pump?
What engine set-up are you running?
01-08-2006, 11:25 PM | #3 |
Assuming a 350, check out this url. It has a lot of pictures that may help you get started. Good luck.
Larry http://67-72chevytrucks.com/vboard/s...ong+water+pump |
01-08-2006, 11:42 PM | #4 |
The majority of the long water pump, ps pumps, hung from the water pump itself
01-09-2006, 12:12 AM | #5 |
If I remember correctly, one bolt threads into the front of the driver side head, with a spacer between the pump bracket and the head that is about 3/8 thick. Another bolt threads into the water pump. The other side of the pump attaches to the front of the exhaust manifold. Here's a lame picture I found on my computer.
01-09-2006, 07:09 AM | #6 |
Sorry, forgot to mention I'm running a BBC.
01-09-2006, 09:31 PM | #7 |
Ratrod,
Here are a series of pictures with the brackets. Hope they help. Larry |
01-09-2006, 09:35 PM | #8 |
Ratrod,
I just assumed you are using a one piece pump. If you are going with the pump with fender mounted reservoir, these may not be of any help. Mine is the same set-up as you would find on the BB Chevelle for these years. Larry |
01-09-2006, 09:44 PM | #9 | |
01-09-2006, 11:20 PM | #10 |
Ratrod,
You are welcome. Glad to help. Good luck. Larry |
