01-10-2006, 09:49 PM | #1 |
Lowered BBC, and Frame off-ers
This truck project is going to drive me further over the edge of sanity...anyways I have a couple of questions, first off, I plan on dropping the front of my truck 3-4inches, well already from time to time when I hit a bump in the road the bottom of the collectors on my headers hit. I think I remember something about someone running a pair of car headers, like maybe from a chevelle? Does anyone know about this or can point me in the right direction?
Question 2-I am wanting to replace the leaf spring bushings, How do you do this? I got a propane tourch and a press, any pointers? And what about the A-arm bushings? Should I replace them now or just not worry about it? Thanks for any help guys.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
01-10-2006, 11:06 PM | #2 |
Re: Lowered BBC, and Frame off-ers
I have heard of people runnin Chevelle headers.Ive got Sanderson shortys on my 454 cause the full length headers where draggin
75 GMC C-15 short/step factory 454, lowered |
01-10-2006, 11:31 PM | #3 |
If it a big block , a set of Hooker Competition (NOT SUPER COMPS)headers for a 68-72 Chevelle or a 70 -74 Camaro will do what you want (same part number ). They have 2 inch primaries and 3.5 inch collectors I think and fit just about level with the frame rails . You will have to trim the driver side frame rail on top to clear one of the tubes . A friend ran these on his truck with good results and the headers are big enough to let a nice BB breathe . His truck was an 82 SWB and I dont ever remember them dragging . I have seen the same application used for small blocks also but I dont know what trimming , if any , is required . Frank
Born and proudly residing in a Red State ! |
01-11-2006, 12:13 AM | #4 |
Thanks a ton guys! Hmm...Dad has a 68-72 chevelle with a BBC...I may need to borrow his headers for mockup...
01-11-2006, 11:29 PM | #5 |
Someone on this board is running those headers but I dont remember exactly who . Maybe AIRMALE (Sp?) . You might search the board . There was a discussion about them around 6 months ago . Frank
01-12-2006, 12:51 AM | #6 |
Thanks, anyone know about the leaf spring bushings? I know some one around here has changed them before.
01-12-2006, 02:01 AM | #7 |
Professional Grade
Thats a sucky job David!
Gotta burn the rubber outta the end of them with a torch, then scrape the rest out
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-12-2006, 12:49 PM | #8 |
www.73-87chevytrucks.com
I linked pictures to the Sanderson headers I am using on my truck in this post:
http://67-72chevytrucks.com/vboard/s...d.php?t=185391
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-12-2006, 06:12 PM | #9 |
Chris...very nice, same ones I have on mine.
01-12-2006, 08:12 PM | #10 |
The Hooker comps, NOT SUPERCOMPS work. I believe it's part number #2455. 2"primaries and 3 1/2" collectors full length and tuck up between the frame.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
01-15-2006, 06:23 PM | #11 |
Thanks guys, does anyone have any pictures of were on the frame you need to notch?
01-15-2006, 08:31 PM | #12 |
My friends notch was on the top of the frame where the tube comes down from cylinder 7 . Airmales doesnt look notched in the pic so maybe it isnt necessary . It was a very small notch and my friend may have just thought he needed to notch it . Frank
01-17-2006, 12:09 PM | #13 | |
01-16-2006, 01:30 PM | #14 |
Awesome, thanks a ton for the help guys.
