Old 01-12-2006, 11:25 AM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Those who have Hedman Hedders I have a ?
I installed my new hedmans last night. The issue is that the driver side header is hitting the back of the lower A arm. I mean it bolts up fine but it is actually touching the a arm. Anyone else have this issue? Before i get flamed i will take some pics tonight.
chevyguy_72 is offline   Reply With Quote
Old 01-12-2006, 11:29 AM   #2
72MARIO
72MARIO's Avatar
Re: Those who have Hedman Hedders I have a ?
There is a younger guy here that had that same problem.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-12-2006, 12:19 PM   #3
70rs/ss
70rs/ss's Avatar
I had a similar problem, I checked the A-frame for alignment (in the U-bolts) then I loosened them up (the U-bolts) and slid the A-frame forwand a 1/2" and it cleared beautifully. I went through three or four different headers to find that I liked the Hooker Coms and they fit the best, but not perfect.
70rs/ss is offline   Reply With Quote
Old 01-12-2006, 12:36 PM   #4
Bob D
Rolled on Paint Club
Bob D's Avatar
I have Headmans on a small block with no problems.
Bob
Bob D is offline   Reply With Quote
Old 01-12-2006, 03:46 PM   #5
CoolRide
CoolRide's Avatar
This is good to know! I'm just getting ready to order some headers for my sb 67 and was wondering which brand fits the best.
CoolRide
CoolRide is offline   Reply With Quote
Old 01-12-2006, 04:23 PM   #6
chevyguy_72
Vintage Evil
the fit is beautiful other than this issue. And hopefully i can slide it forward like it says in one of the above posts
Old 01-12-2006, 04:45 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have Hedman ELITE Headers on my 4wd Blazer, Perfect fit
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-21-2006, 03:57 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Someone above me made a good point, if your Motor mounts and Trannys
mounts are USED, then they might rub, I had that problem on my old 67, I
thought it was the headers, turned out to be a squished motor mount
Old 01-12-2006, 05:56 PM   #9
BubbaGreen
I too have hedmen elites on a 71, its a good fit. I did grind into the frame approx 1/8" on both sides around one of the tubes (cant remember which) just to make sure the tubes dont rub the frame. Its close to the lower a-arm on one side as well, but clears without issues. This is a 2wd w/sbc350 in stock position.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 01-12-2006, 06:07 PM   #10
MrC1
Dork For Days
MrC1's Avatar
Question Re: Those who have Hedman Hedders I have a ?
Not to take over the thread, but anyone know if big blocks have the same issues? I've heard alot about the SB issues, but little about BB ones.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 01-12-2006, 10:27 PM   #11
ratrod67
ratrod67's Avatar
I have Hedman Elites in my 72. They fit fine. I tried 2 sets of Hookers and both hit either the oil pan or the frame mounts.
ratrod67 is offline   Reply With Quote
Old 01-12-2006, 06:47 PM   #12
72MARIO
72MARIO's Avatar
You cant slide the A arm anywhere. It has a alignment pin in the crossmember and it has to stay where it is. Unless it's not set in correctly now but I dont think that's possible.
2005 TAHOE DD
Old 01-12-2006, 09:24 PM   #13
RPMkid
I have hedman's on my truck.And it rubs the passenger side frame.
Also when I ordered them I ordered them for a manual trans.And they sent me the auto one's.So they rubbed the z-bar.I had to use a BFH to get them to fit.
RPMkid is offline   Reply With Quote
Old 01-12-2006, 09:46 PM   #14
nined7chev
nined7chev's Avatar
Had the same problem. Replaced the tranny mount and it straightened everything out.
nined7chev is offline   Reply With Quote
Old 01-13-2006, 08:57 AM   #15
68C15
blood type; Retumbo
68C15's Avatar
this is something to look at. also, is the motor in the original position?
I have the regular Hedmanns on my lowered 68 using original arms with '80 spindles. I think my engine is in correct. I measured another 2wd just to make sure. no problems at all.
68C15 is offline   Reply With Quote
Old 06-21-2006, 10:37 PM   #16
clif1968
Junior Member
clif1968's Avatar
Same with my hedmans, Summit part number HED-69090, fit great on the drivers side, rubs the frame on the passenger side.
Clif
'68 C/10 LWB, 327, TH400, 12 bolt
clif1968 is offline   Reply With Quote
Old 01-12-2006, 10:13 PM   #17
JRB
JRB's Avatar
Could this have anything to do with the truck being lowered? Or is it lowered?
JRB
Does Doug Thorley Make headers for these old trucks? I know there expensive but I dont think I have ever heard a bad thing about Doug's except how much they cost.
JRB is offline   Reply With Quote
Old 01-12-2006, 10:28 PM   #18
Sweet72
Sweet72's Avatar
Yes, Thorley has a Tri-Y header for the 67-72's I'm also considering Stan's Headers which are a Tri-Y design and only a few bucks more but the flange doesn't have the welded O-ring design, they're machined flat and Stan claims the welded O-ring causes leaks. Doug Thorley used to work for Stan's Headers.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-12-2006, 11:36 PM   #19
76bonanza
76bonanza's Avatar
do the thorleys turn blue at all? Being nickle and chrome just think they will discolor quickly not sure tho.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 01-13-2006, 12:00 AM   #20
72MARIO
72MARIO's Avatar
My uncle has a set of Doug Thorleys on his 77 4x4 BB.
They look crappy after a few years it's a corrosion protection coating and there was no warranty on it. The shop made him aware of that before the purchase. They did turn blue and rusty after a few years sitting on the truck outside. They are a really thick tube think 14 gauge ? That's why he bought them not for long lasting looks. They tend to rot from the inside out.
2005 TAHOE DD
Old 01-13-2006, 02:17 AM   #21
kevncar
Active Member
kevncar's Avatar
For the BB guys...has anyone tried sanderson headers? Good or bad comments would be great. I am getting ready to swap out my small block for a 454/TH400 and I need to decide which headers will work. By the way...I'd like a 3/4 length header for ground clearance being that I want to bag this thing someday. Also, it sounds like the motor mounts can be an issue. I was looking at the set performance online offers.
http://www.performanceonline.com/sto...cat=455&page=1
Kevin
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 01-13-2006, 05:15 AM   #22
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have Hedmans on the 350 in my '71 Jimmy [K/1500]. They were a tight fit, but I did have to joggle the ears on the Z-bar to make the end of the lower clutch rod miss one of the downtubes. The other issue is that you have to completely pull off the passenger side "hedder" if you have to R&R the starter. Outside of the occasional tightening of the bolts on the exhaust plate to eliminate leaks -- common to any headers -- they have worked well for 7 years in this truck.
Old 01-13-2006, 02:12 PM   #23
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
I installed Hedmans on my lowered '70 350 4-speed and they fit with out any problems.
I now have Hooker Comps on the same truck and they fit just as good or maybe a little bit better.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 06-21-2006, 03:31 PM   #24
ol' truck
~one mean a$$ truck~
ol' truck's Avatar
I have a set of headers that will not fit. they are hitting the frame on the driver side, and will not move anymore.. I am not sure what brand they are tho... mine is 71 fleet
ol' truck is offline   Reply With Quote
Old 06-21-2006, 05:08 PM   #25
70GMCer
70GMCer's Avatar
I had to indent the tube 1/4" to clear the frame......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
