Old 01-14-2006, 12:03 PM   #1
jberkeley
86 chevy k-10
need help!!!
i have a chevy 350 78 block, my problem is i can't keep my distributor tight....
does anyone have any ideas on how to fix this problem?? has anyone ever seen this?? i tried i think everything, new gasket, longer bolt, even tried a rubber oring... please help.....
jberkeley is offline   Reply With Quote
Old 01-14-2006, 12:05 PM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: need help!!!
you may have to drill out the hole to a larger diameter and run a tap through it to thread it. before trying that i would try loctite if you havent already. youd have to be very careful when drilling out that hole as to not get metal shaving inside your intake manifold
chev74 is offline   Reply With Quote
Old 01-14-2006, 12:29 PM   #3
gentry69
gentry69's Avatar
Re: need help!!!
how long of bolt are u using u should only use a bolt that is about 1/2 long maybe the bolt u are trying is bottoming out or maybe a new clamp. but i could be wrong it has happened a time or to.
gentry69 is offline   Reply With Quote
Old 01-14-2006, 05:08 PM   #4
jberkeley
86 chevy k-10
Re: need help!!!
i've tried various bolts, replaced distributor, also changed hold down even tried locktite, any other suggestions....thanks
Old 01-14-2006, 08:12 PM   #5
chev74
Addicted to Chevy
chev74's Avatar
Re: need help!!!
possibly take your existing hold down and bend the ears down so that it has more tension on the distributor base. this may need to be done in conjunction with the bigger threaded hole
Old 01-14-2006, 09:57 PM   #6
jberkeley
86 chevy k-10
Re: need help!!!
well i tore my shop apart, to find an old hold down, longer in length,. used three oversized washers and a new oring.. problem i think is fixed, it seems a lot tighter than before.... anyway thanks for the replies....now
