01-14-2006, 09:04 PM | #1 |
need a socket size please
What is the size of the pinion nut on a 71 C-20 2wd with a Corporate rearend? This is a 3/4 ton Longhorn.
My parts book suggests 1 5/16" and the only rear end that I have to measure is a 3/4 ton 4x4 and it measures 1 5/8". I am needing the correct socket size and pinion seal # ASAP. Thanks.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide Last edited by nu2-72; 01-16-2006 at 11:49 AM. |
01-15-2006, 05:00 PM | #2 |
Re: need a socket size please
come on folks. someone has worked on one of these.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
01-15-2006, 06:10 PM | #3 |
Cantankerous Geezer
Pinion nut for the 10 bolt is 1-5/8". It has to be a thin wall socket, an impact socket won't fit into the trunnion.
Fred There is no such thing as too much cam...just not enough engine. |
01-16-2006, 11:52 AM | #4 |
Having a little discussion with the local dealer. He says all Longhorns were Dana equipt. I do not think so.
01-17-2006, 06:05 PM | #5 |
Cantankerous Geezer
From what I remember the 10 bolt cover is the HO52/72. 12 bolt cover is Dana.
01-17-2006, 07:11 PM | #6 |
Fred, you are correct. I have all the pics and ammo needed to go back to the dealer now. He is a kid that I grew up with, (much younger than me though) and knows everything, if you know what I mean. He had a 66 Camper Special and so all Campers and Longhorns had Danas based on his experience. His exact words, "If you can put lube in through the cover hole, it is a Dana." I tried to explain that the cover is round and a Dana cover is egg shaped with flatter lines. Eaton is 10 bolt and Dana 12. He says I am crazy. Maybe I am crazy but crazy right. I was searching for a gasket and pinion seal. Thanks for your help.
01-18-2006, 02:10 AM | #7 |
Cantankerous Geezer
Just in case you need them. Fel-pro gasket number for the HO52.
Differential Cover RDS5088 Pinion Seal 411330N Pinion Repair Sleeve 99259 Axle Seals 2081 If you haven't had one apart you need to be ready for a tight nut. It was installed with around 200 ft-lb of torque. I use a 3/4" drive impact gun. If you don't have that luxury, a big pipe wrench with a cheater to hold the trunnion, turned against the frame. And a cheater for the nut. Sometimes you also have to heat the nut, propane torch will work. Before you loosen the nut, mark the nut and pinion shaft end with a center punch. Then count the turns so you can return the nut to the same position. That way you don't have to reset the pre-load on the bearing. Also don't forget to check the housing vent. If it's plugged, you will blow out another seal before long. As you can tell I've done this a few times. The HO52 was used from 1948-1972.
01-18-2006, 10:56 AM | #8 |
Fred T, outstanding info. That is the type of stuff I need. Thanks.
01-18-2006, 01:56 PM | #9 |
Cantankerous Geezer
One thing I forgot. When you put it back together, use anti-sieze compound on the pinion threads and shaft. The stuff makes a nasty mess when you get it where it shouldn 't be, but the next time you have to take it apart you will be happy you used it.
01-19-2006, 05:35 PM | #10 |
That's why I love this board so much!!
So much good info, everybody knows something! Thanks for all the help you guys!! You know who you are! Cya, Edmond Dutch Longhorn
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- The Netherlands |
01-21-2006, 05:42 PM | #11 |
Package on the way.
01-21-2006, 07:23 PM | #12 | |
Also started on the rear brakes today with the help of my good friend Jan Suburban. Will keep you updated on the progress. Talk to you later!! Cya, Edmond Dutch Longhorn
01-22-2006, 03:07 PM | #13 |
Are you changing the prop. valve? If not, let me know how it works and if you need one later I will fix you up.
01-22-2006, 05:44 PM | #14 | |
and maybe putting in one of these: If that doesn't work than I will want a different prop. valve. Today we did the driverside. All I need now is two new brake hoses. When I bought the calipers the guy said I could use the existing plumbing. I forgot about the different connector for a disc caliper, so now I have to get some new hoses for disc calipers. I hope to get them tomorrow. I'll keep you updated on the progress. Cya, Edmond Dutch Longhorn
01-22-2006, 10:14 PM | #15 |
Nice. You know I am jealous and years from driving my truck.
