01-17-2006, 05:22 PM | #1 |
LOOOONG Bed to SHORT Bed conversion questions
I know there are tech articles on this, but I'm getting ready to take the plunge into this and have some questions about minor details..... so far this is what I have learned:
Take 14" out behind the cab, and 5" off the back Install shortbed gas tank Install shortbed drive line I get this stuff, what exactly do you guys do with the brake lines? I know it's impossible but I want to make this as painless as possible and have everything ready to go, so and advice on things I'm missing go ahead and fill me in..... |
01-17-2006, 06:17 PM | #2 |
Re: LOOOONG Bed to SHORT Bed conversion questions
I went to the junk yard and found a line off a short bed truck. There is a junction under the cab that is the same location on both. Take it loose there and from the flex line that runs down to the axle and your set. I ordered a new set of parking brake cables from LMC. I think they were like 10 each. You can have your stock (providing it was 1 piece) driveshaft shortened. I had mine done, balanced with new joints for $80.
Other than that, measure about 5 times before you cut. I used the new short bed to help make sure that everything was where I wanted it. If you have the long springs in the rear there will be no room to run a bumper unless you weld it on b/c there will only be about 2" of from the shackle mount. If you get the shorter springs its only a matter of removing the rivits and moving the shackles up to the next location on the frame. All the holes are already there.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
01-17-2006, 11:35 PM | #3 |
No No
From what Ive read you would be much better of finding a beat to crap shortbox and swaping things over. Either way
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
01-22-2006, 12:27 AM | #4 | |
driving is in my blood
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-19-2006, 12:12 AM | #5 | |
Web Wheeler
Your auto parts store should have assorted lengths of brake tube that's pre-flared with nuts on it. If its too long, bend a loop-de-loop or pretzel in it... kind of like this.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
01-19-2006, 12:31 AM | #6 | |
Gentleman Jim Driver
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
01-19-2006, 12:35 AM | #7 |
Compression fittings aren't really intended for that type of pressure. Best to flare them and use the brass unions. Not trying to argue
-Jeremy
79 Jimmy slammed AKA James Down |
01-19-2006, 03:32 PM | #8 |
I think what I will do is just get lines from a short bed, seems the easiest to me. So is there anything I'm leaving out besides what I mentioned earlier?
Take 14" out behind the cab, and 5" off the back Install shortbed gas tank Install shortbed drive line Shortbed brake lines Short leaf spings if I don't have them.... Anything else??????? Thanks for all the help so far. |
01-19-2006, 06:28 PM | #9 |
You forgot at least one thing . Enjoy the Short wheel base when youre done ! Frank
Born and proudly residing in a Red State ! |
05-13-2009, 10:54 PM | #10 | |
its just $$$$$
06-30-2009, 10:24 PM | #11 |
Would this work for a 1978 lwb to swb or would i just compare that to another 1978 swb.
Probably no but if anyone knows that would be great. Thanks |
01-22-2006, 01:02 AM | #12 |
Happy to be here
Have you looked at this article in the FAQ Forum-How to shorten a LWB frame It pertains to a 67-72 frame but it is very well written with great pics.
04-10-2009, 02:40 AM | #13 |
content removed by forum staff
05-13-2009, 09:44 PM | #14 |
Longbed To Shortbed Conversion
Ive shortened numerous 1960-1972 chevy trucks as well as a few 50's & 60's stepside pick ups. I can shorten the bed and the frame of the truck. Once its done you can never tell it was ever a long bed. If you have a short bed "bed" you can save a few bucks by only getting the frame shortened. I shorten the frame of the truck in such a way where all of the structural integrity of the frame is maintained without any plating, boxing, or bracing. As well as it still looks like the original frame. Here is a picture of a converted 1972 chevy truck. The frame as well as the bed floor and sides were converted. Yes the bed sides were originally longbed sides. The long bed sides and bed floor were cut and re-welded back together, I have done quite a few of these year pick ups. |
07-01-2009, 09:29 AM | #15 |
why convert??? long beds RULE!
76 Chevy Fleetside 63 Lincoln Continental w/ Ford Racing 460 (550hp) 2012 VW GTI 2013 Escalade 2008 Harley |
