Old 01-19-2006, 02:19 PM   #1
ScienceGuy
ScienceGuy's Avatar
Which A-arms will interchange with 72 truck?
I just found that one of my lower a-arms is bad. Does anyone know if any other a-arm from say a chevy truck or car is interchangable with that of a 72 chevy c-10 (2WD)? Thanks
72 Chevy C10 Custom Deluxe
03 Camary (Family Ride)
96 Jetta (piece of sh**)
ScienceGuy is offline   Reply With Quote
Old 01-19-2006, 03:27 PM   #2
buildin72
buildin72's Avatar
Re: Which A-arms will interchange with 72 truck?
From the help iv recieved from guys on this board....63-87 crossmember and a arms will work. If you go with the later style arms..you will automaticlly have a disc brake set up, a arms, crossmember, the whole 9 yards!!! I think they told me with the 73-87 crossmember, that you will have to elongate 2 of the bolt holes for it to bolt directly up....NO big deal. This is what i am planning on doing to my truck. I think it will be cheaper in the long run, and work exactly the way it should. Hope this helps.
I found the link to info that might help:::
http://67-72chevytrucks.com/vboard/s...d.php?t=184458
**If i missguided this in anyway...someone please correct me!!!**
A.Y.
-ADAM
2006 GMC Sierra 2500HD 4x4
Reg. Cab
Long Bed
LBZ Duramax
Allison 6sp
1970 Chevy C/10
Short Bed
buildin72 is offline   Reply With Quote
Old 01-19-2006, 03:45 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
He just has a lower "A" arm that went bad. The 71-72 are the only ones that are the same, however you can use anything from 63 to 72. The 63-70 would need a ball joint change and the steering bumpstop is a little larger so you can't turn as tight. The 71-72 of coarse are direct bolt and you would maintain your turning radiouse. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-19-2006, 05:51 PM   #4
ScienceGuy
ScienceGuy's Avatar
Thanks Wes, and others..Time for me to hit the swapmeets.
Old 01-19-2006, 03:50 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
If you just want so switch out one A-arm you probably want to stick with a 71 or 72. The 67-69 trucks had drum brakes and the bump stop for the steering is different on the lower A-arms. You can use a 67-69 A-arm but you will need to grind down the "tit" on the spindle so that your wheels will turn as far as they need to (I used stock 67 lower A-arms with a stock 71 disk brake spindle and I had to grind the "tit" down so I could turn my wheel properly from lock to lock). I don't know about any other years. What I have listed is the extent of my experience. The upper arms are all exactly the same (67-72) except the 71 and 72 used a different sized ball joint.
Edit: You beat me to it Wes.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-19-2006, 05:10 PM   #6
68haywagon
I'm watching you!
I'm in the same boat...literally just found it 15 min ago while taking them apart. Oh well, thats the chance you run with 30+ yr old parts.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 01-19-2006, 05:33 PM   #7
67ChevyRedneck
Mike
I bought a complete 71 GMC front disk brake suspension for my truck. It looked really good, but was covered heavily in grease. When I cleaned it up I found the passenger side lower A-arm had taken a hard hit (like from a tree stump or something) I didn't have this board for info and I saw the bump stops were different so I used both the lowers off my '67. After I had it all together I found I could hardly turn my wheels. That's when I figured out I had to trim the "tit" on the 71's disk brake spindle Oh well, it all works great now....
Jesse James
Project "On a Dime"
Old 01-19-2006, 05:53 PM   #8
68haywagon
I'm watching you!
Mine is messed up at the shaft. The hole is an oval, and all the threads are stripped out. Mine was off of a 71 rolling chassis I bought. Impossible to see while everything was together. Thats the only one I took apart today, but the others look to be in good shape.
