tremic tko 500
im getting ready to start restoring my 71 stepside and i want a strong 5 speed and was just wondering if anyone here knows anything about putting a tremic tko 500 in a 71 chevy. you can mount the shifter in like 3 different places but i was just wondering where the shifter would come up through the floor board at. i like the power the tremic is suppose to be able to handle cause im hoping to get no less then 450 hp out of the engine. thanks alot
Re: tremic tko 500
Do you have the tranny already? Contact www.keislerauto.com. They might be able to give you some helpful info.
![]() Join Date: Jan 2000
Re: tremic tko 500
I have a TKO in my 71 shortbed stepside.
The middle shift location works great if you have a bench seat and the motor is mounted in the 6cyl location. You can use your 71 bellhousing and flywheel. You will need a clutch disc for a T-5 equipped mid 80's camaro application. The other issue is that the throwout bearing retainer on the TKO is 4.683 in. daimeter and the 71 truck bellhousing has a 5.125in.diameter hole for the throwout bearing retainer. It is really a good idea for long transmission and clutch life to have a spacer ring pressed on to the TKO bearing retainer to make up the difference from 4.683in. to 5.124in. I had mine made at a local machine shop. Last edited by Willy Prost; 01-25-2006 at 06:16 PM. |
Active Member
![]() Join Date: Nov 2005
Re: tremic tko 500
I am planning on getting one of these, because the gear ratios will be just about ideal for use with a Cummins 4BT (which I will be putting in at some point in the next year).
![]() The whole setup should be running at peak efficiency at 71 mph - perfect! Last edited by cell; 01-25-2006 at 11:29 AM. |
