01-27-2006, 04:45 PM | #1 |
Transfer Case Question...?
What transfer case do I need? I have a 68 3/4 ton 4x4. It has the 4 speed trans with granny 1st gear. I guess it currently has a Rockwell transfer case in it(???) I am thinking of converting to a Auto Trans (TH350/TH400). I'm supposing I need the NP205C transfer case. Do I need the 27 spline input or 10? fixed or slip rear yoke? I see they used the NP205C from 69-86 what years are all the same as I need?
Also, What is the Rockwell issue? Are there no adapters to use my current transfer case behind a TH350/TH400? Or is it not worth using? Please enlighten me on some 4X4 info... P.S. oh, it's the truck in my avatar...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
01-27-2006, 08:44 PM | #2 |
Re: Transfer Case Question...?
Have you gone to Advanced Adapters site to see what they may offer. JOHN
01-27-2006, 09:20 PM | #3 |
BlahBlahBlah
have you asked this question in the 4x4 area? those guys really know their stuff.
01-28-2006, 12:14 AM | #4 |
Your probably better off finding a complete 205 transfer case and trans combo. ..original late 69 to 72 units used the NP205 with 27 spline adapter to the turbo 350 and had fixed yoke.
If you want the 400 trans you need a NP205 with a 32 spline female adapter ..but as mentioned above..advance adapters has modification unit pieces to convert different combinations to work.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
