Old 01-30-2006, 10:18 AM   #1
greg0380
rear leaf springs, what will fit??
I have an 85 1/2 ton 2WD, and I want to replace the rear leaf springs. First question is, right now I have a mismatch setup, driver side has 6 leafs, passenger side has 4 leafs. Would this cause the rear to hop on acceleration??
Second question, what would fit? Most parts places specify 4 leafs, but I would like to go with 6 or 8 but they list them as for 4WD and i was told they wont fit. But as long as the measurement from eyelet to eyelet is the same wouldnt they work?? Aren't all the leaf springs for this year the same length?
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305
5 speed, 3.42 rear
2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L
1999 BMW 528i
greg0380 is offline   Reply With Quote
Old 01-30-2006, 02:32 PM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: rear leaf springs, what will fit??
Hmm, that's odd. Does the rear end sit crooked? I'm not too familiar with that body-style truck, but I do know that both sides should have the same amount of leaves in the pack. That could be one of the reasons why you are getting axle-wrap. What are you trying to accomplish with your truck? Are you wanting to raise it up in the back? If you go to 6-8 leafs out back your truck will probably ride like a dumptruck. Let us know more of what you are trying to accomplish.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-30-2006, 03:12 PM   #3
greg0380
haha, the reason one set has 4 springs and the other has 6 is because of me. I bent one side and threw in a 6 leaf spring set in a pinch!
The truck sits straight, but I want to be able to load more and not have it sag so much when I pull my boat. I currently have a 2 inch lift block under the rear springs.
5 speed, 3.42 rear
1999 BMW 528i
Old 02-03-2006, 01:32 PM   #4
greg0380
ttt
5 speed, 3.42 rear
1999 BMW 528i
Old 02-13-2006, 07:33 PM   #5
corn
Heavy half is the 7 leaf pack & light duty is the 5 I believe. Thats counting the overload spring...
corn is offline   Reply With Quote
Old 03-17-2006, 08:01 PM   #6
rodnut randy
what will fit, my problem is a 70 1/2 ton frame with 5 leaf springs. I try to buy new leaf springs and the axle alignment bolt is in middle (26in.) where mine is 24 from front to bolt and 28 from bolt to rear. also replacement is a 2 1/2 wide spring where mine is a 2 1/4 spring and a 2 1/2 will not fit in my hangers. my thought is my truck is screwed up, but why is it when I bought a new replacement front spring hanger for my truck it was the narrower setup. I think 2 spring mfg. I talked to do not have listing on 68 to 72 and one sold me 73 to 87 leafs.
rodnut randy is offline   Reply With Quote
Old 03-18-2006, 11:48 PM   #7
qksilver
Use an air bag set up. It will level it with a load and won't punish you when empty
qksilver is offline   Reply With Quote
