Old 01-30-2006, 06:10 PM   #1
dubya
Shot in the dark - Explain my transfer case
Hi,
I know this is a bold shot in the dark, but can you help me identify my transfer case?
I have a '72, K20, 350/th350, 8-bolt wheels with 9/16" studs.
I'm not currently able to look at my transfer to tell, but can you explain some differences in original transfer cases available? This is so when I get home, I can say "Yeah, that's what they were talk'n about" :-)
TIA,
W
dubya is offline   Reply With Quote
Old 01-30-2006, 07:22 PM   #2
MJN
MJN's Avatar
Re: Shot in the dark - Explain my transfer case
If it's a true '72 drive train it will be a NP205. It will be a cast iron case. The rear bearing retaining cover (to the right of the rear output yoke) will be aluminum. The shift pattern (front to back) 4lo, N, 2hi, 4hi. Hope this helps some.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-31-2006, 11:42 AM   #3
dubya
Thanks that's what I have. 4lo, N, 2hi, 4hi pattern, and aluminum cover...
Follow-up questions:
The bolt pattern where the tranny meets the case looks to be a square-oval, and not a road-race track pattern (not symentric around the center). I'm thinking of swapping to a NV4500 if I can get the war-dept. (wife) to pony up some cash. I have a non-stock 400sbc in it now. Any gotcha's, neat tricks, major problems that I may encounter? Does the NV4500 marry up to the motor, or is a adapter/new bell housing in my future?
I'm considering going with stock linkage for the '72, and adapting that to the tranny, but I've seen where guys stuck with the hyd. linkage. I'm sure it comes down to preference and maintenance, but what's better?
TIA... Maybe I should make a new thread for my followup ????
W
Old 01-31-2006, 07:01 PM   #4
1969 GMC
1969 GMC's Avatar
W
if it is indeed a TH350/NP205, then it will be the racetrack bolt pattern. a NV4500 won't just "bolt up."
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-31-2006, 07:06 PM   #5
CraigS
And you can't run a mechanical linkage clutch with the NV4500 without a lot of modification because it's set up for hydraulic. There won't be a clutch arm and pivot point on the transmission.
72 GMC K20, 454, TH350
00 GMC Yukon
66 Ford Bronco
CraigS is offline   Reply With Quote
Old 02-06-2006, 02:12 PM   #6
dubya
Which brings me back to one of my questions:
will a NV4500 bolt into a '72 bellhousing?
If you look here, you can see the nuckle/clutch arm hole.
http://cgi.ebay.com/ebaymotors/68-72...ayphotohosting
Old 02-06-2006, 07:24 PM   #7
CraigS
I thought that the NV4500 had an integral bellhousing.
00 GMC Yukon
66 Ford Bronco
Old 02-06-2006, 10:08 PM   #8
kwmech
No, it will not bolt up, you have to buy a custom housing from Advance Adaptors that will use your existing clutch linkage
