Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-04-2006, 02:23 PM   #1
GM72K10
Next!
GM72K10's Avatar
missing key
Bought a truck from an impound yard today, no title and NO KEY! Other than getting a locksmith to come out, any way of getting an ignition key? Truck is an 84-86 C20, with a 4speed. Any way of unlocking the locked steering column with out breaking something? This truck may move under its own power . . .
thanks guys.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 02-04-2006, 04:03 PM   #2
beaterC10
Re: missing key
If you have the time, you could pull the steering wheel and lock plate and replace the ignition tumber. You would need a steering wheel puller, lock plate compressor, either torx or phillips screwdrivers, and a small pick. I have done this on columns off the truck in about 15-20 minutes. What would a locksmith charge? If it was me I would consider having it towed. Here in Indy you can get a truck moved anywhere in the city for around $50.
The only way I know to defeat the column lock without screwing up the column would also require pulling the wheel and lockplate. If you have a four speed tilt column, you DON'T want to screw it up, those things are tough to find.
beaterC10 is offline   Reply With Quote
Old 02-04-2006, 04:21 PM   #3
1969owner
1969owner's Avatar
Re: missing key
new switch
1969owner is offline   Reply With Quote
Old 02-04-2006, 05:39 PM   #4
GM72K10
Next!
GM72K10's Avatar
Re: missing key
good news and good luck. Had the truck towed to my place. Went through some old junk keys, found one that worked!~ Think I got a real steal. Turns out the truck is a Siverado 30 1 ton, single wheel, 3:73 posi, dual exhaust. runs damn good. Bought it for the bed. Its rust free! In fact the doors and front clip are good also. Someone painted this original Red truck with a cheap white color, also looks like truck belonged to some kind of construction company. Quite a steal, $400.00 delivered. Will post pics tomorrow. thanks for the advice on the missing key guys.
86 K30 CUCV M1028A1
Old 02-04-2006, 07:32 PM   #5
beaterC10
Re: missing key
Sounds like you did real good. Would you be interested in selling any of the hydraulic clutch parts? I need the pressure line that runs from the master to the slave cylinder. If you don't want to split it up, I might be interested in the entire set-up.
Old 02-05-2006, 07:10 PM   #6
pugs
pugs's Avatar
Re: missing key
where in Pa are ya? if you are going to part the truck out i mite be interested in some parts if ya are close enough
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 02-05-2006, 11:10 PM   #7
GM72K10
Next!
GM72K10's Avatar
Re: missing key
thanks for the interest guys in the parts. too early to tell how I'm going to part it out. I need to have it move under its own power for a while yet. Located halfway between Allen town and Phila.
86 K30 CUCV M1028A1
Old 02-12-2006, 08:33 PM   #8
marvxyz1
marvxyz1's Avatar
Re: missing key
Can you get a title for such a deal in Pa.???
marvxyz1 is offline   Reply With Quote
Old 02-13-2006, 07:10 AM   #9
GM72K10
Next!
GM72K10's Avatar
Re: missing key
I suppose but I bought it under the assumption that I would part it out, which I'm starting on. Before anyone PMs me though, it will be a while before I'm ready to sell anything. I need it to move on its own until warm weather.
86 K30 CUCV M1028A1
