02-07-2006, 02:01 PM | #1 |
BlahBlahBlah
wtb....painless...or ???
if you're a dealer for painless could you please pm me your price for the complete harness kit front to rear for a 1971 halfton 4x4 long box.
or if you sell something you feel is superior or had bad experience with painless etc etc i would appreciate any feedback...thanks mark |
02-07-2006, 09:41 PM | #2 |
Re: wtb....painless...or ???
Bump, I need one also (part # 10206).
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-08-2006, 12:41 PM | #3 |
Just an FYI: The painless harnesses dont come with all the connectors needed to just plug in their wiring. Also the fuse box is different. However, if you're gonna be adding alot, doing custom mods...they are great.
If you are just wanting to replace existing wiring with new, then you might want to go with M&H. There site is www.wiringharness.com They are by far the best for direct replacement and can be ordered with simple mods, such as HEI options and a few others. I have used both and both are good quality, each one has its benifits.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
02-09-2006, 12:09 AM | #4 |
BlahBlahBlah
thanks for that info BG
02-09-2006, 12:30 AM | #5 |
someday it will be done!
I bought the painless kit (10206) awhile back though it isn't installed yet.
I believe the only connector that isn't included is the cresent shaped one for the steering column (you need to salvage that one if you're using the original column). The box is different in that it uses modern plastic fuses instead of the old glass ones and it has a lot more available circuits (18 IIRC).You will also need to enlarge the opening in the firewall for the box slightly,but the kit has a template for that.Every wire is labelled every 6" to tell you what it is and the kit includes a ton of crimp connectors for hook up. It's enough to make me look forward to wiring my truck!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
02-09-2006, 06:44 PM | #6 |
FYI: The template that is printed in the manual....even though it says "actual size" is not correct when cut out. My suggestion is find a piece of card board like that at the back of a legal pad, make the cutout on that and test fit it to the fusebox...prior to cutting sheet metal. Just keep the orientation correct if this is what you end up doing...TEST fit everything before paint.
02-09-2006, 10:07 PM | #7 |
CG you got a pm from me. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
