Old 02-07-2006, 08:01 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need a quick measurement...
I picked up a front crossmember today for my 72 half ton so I could chop it.. Could someone measure inside to inside width for me this thing looks tweaked.. from center bolt to center bolt.. Any help would be great...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-07-2006, 08:31 PM   #2
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
Re: Need a quick measurement...
I've got a fresh 3/4T rolling chassis out back and a flashlight, but I'm not sure what measurement you want. The 3/4 and yours should be the same I think.
1970 GMC C-25 LWB (middle of frame up)
5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood.
1987 Camaro z28
350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer.
1988 Monte Carlo (Super Stock ashpalt race car)
My Truck
DTerry is offline   Reply With Quote
Old 02-07-2006, 08:52 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
I need the measurement from the inside to inside of this piece... on the top..
MEMBER #6377
Project "7DEUCE"
Old 02-07-2006, 08:56 PM   #4
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
The frame is tapered in that area. I'll go measure it up now.
1987 Camaro z28
My Truck
Old 02-07-2006, 09:09 PM   #5
DTerry
'70 GMC C-25 LWB
DTerry's Avatar
The frame is narrower toward the front (29 1/8")
The rear is 30 1/8"
I still could figure out what you meant by the center bolt, as there are 4 that go horizontally through the frame, and 3 that go down through...
My measurements are taken outside of frame to outside of frame, right at the front and rear of those big angle thingys.
(D)
1987 Camaro z28
My Truck
