Old 02-08-2006, 01:32 AM   #1
72Short_Cut
72Short_Cut's Avatar
roll pan help
im about to send my box to the body shope to get painted and im not sure what to do with the roll pan. the gaps are not the greatest as i have it fitted on and im not a big fan of the gaps on roll pans. id rather weld it up solid but im not sure if that is the greatest thing also becauser it will add more body work time, and i dont know if ill have future problems with craking or such were it is welded because of the stress put on the box. what do u guys think, alot of people weld there roll pans. i love the look of it but will i have problems with it?
-Ryan
1972 Chevy Short Box
Ls1 swap
1977 chevy Chevette
72Short_Cut is offline   Reply With Quote
Old 02-08-2006, 01:40 AM   #2
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
Re: roll pan help
i welded mine on it looks alot better that way i didnt even require very much body work. i've had no problems with it cracking and i use my truck as a truck, you should have no problems.
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 02-08-2006, 01:42 AM   #3
taylorde
Just A Tool Hand
taylorde's Avatar
Re: roll pan help
I haven't known to many people that have had a problem. But if it is not done right you might.
:hit:
taylorde is offline   Reply With Quote
Old 02-08-2006, 08:09 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Re: roll pan help
I say weld it.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-08-2006, 08:24 AM   #5
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: roll pan help
I would weld it up. The guys having problems are the ones running fiberglass pans. They are prone to cracking where they are chemically bonded to the box. You don't have anything to worry about if it's being welded in.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 02-08-2006, 03:55 PM   #6
72Short_Cut
Re: roll pan help
should i weld the box front up to ensure no moving in the box that will cause stress or no.
-Ryan
Ls1 swap
1977 chevy Chevette
Old 02-08-2006, 05:44 PM   #7
67Fleet
67Fleet's Avatar
Re: roll pan help
-Ryan
I wouldn't go that far. It should be fine unless you plan on doing some serious offroading. The box and frame won't be flexing THAT much.
-Bret
