Old 02-08-2006, 01:45 AM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
differential yolks
can you change the yolk on a 12 bolt without removing the cover. mine is worn allowing the u-joint to move back and forth and im finally sick enough of the vibration after almost a year to do something about it
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 02-08-2006, 11:30 AM   #2
Re: differential yolks
Answer:no.You need to get into the rear.Your pinion bearing is probably shot.Next,expect a broken tooth on the ring gear.
Old 02-08-2006, 01:17 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Unless Im missing something I thought all yokes unbolt off the pinion shaft.
http://67-72chevytrucks.com/vboard/s...d.php?t=187706
sneakysnake is offline   Reply With Quote
Old 02-08-2006, 03:09 PM   #4
Ron 586
RIP Mr Ron
Ron 586's Avatar
Yes you can change the yoke without removing the cover,BUT that is probably not the problem. As Special-K said it is probably the pinon bearing going bad. That said, you can even change the bearing and race without removing the cover, but I wouldn't for these reasons. If you have had the problem for a year you may have metal grindings in the rearend. You can pull the plug and run a magnet in the grease or just drain the grease and look to see. The bearings have a preload setting that has to be correct or it won't live long. If you plan to keep the truck it will be cheaper in the long run to have a expert do it if you don't have the tools and experience to do it. Good luck on this whatever you decide to do. Ron (Mr Round Tuit).
Ron 586 is offline   Reply With Quote
Old 02-08-2006, 03:12 PM   #5
jhow66
jhow66's Avatar
Yes. Remove nut-replace seal- add new yolk-tighted nut (add a little blue locite tight).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-08-2006, 06:04 PM   #6
Scrubby
Check out GMTrucks.org
Like Ron said. You'll have to either redo the crush sleeve or make sure the preload is the same as before on the bearing. I have seen that done using a beam style inch-pound torque wrench, but try to find one of those.
Where in Idaho you at?
Scrubby is offline   Reply With Quote
Old 02-09-2006, 02:01 AM   #7
71chevylongbed
Got Horsepower?
i'm in Meridian
i had the axle apart this summer and checked and the bearings are fine. the yolk is worn where the u-joint is allowing the joint to slide back and forth. so it sounds like i can replace it without opening it up. i'll go by the driveline parts shop get another one and a new u-joint then i will hopefully be vibration free!!!
Old 02-08-2006, 10:41 PM   #8
Guess I needs to reiterate.Ok,yes the yoke can be unbolted/bolted (nut) from the front w/o going inside.BUT,I think you should get inside,at least to inspect.
Old 02-08-2006, 11:06 PM   #9
jhow66
jhow66's Avatar
Agree with Special-K if you can move the yolk up and down with shaft removed. Also turn the yolk (both wheels off ground) to check for rough bearings.
