07-19-2002, 11:56 PM | #1 |
Its moving now to lower it
I bought lowering spindles that use 73 ball joints and i would like to install disc brakes. Now what.
07-20-2002, 08:17 AM | #2 |
Well I just happen to have the perfect kit for you. Both our 5 & 6 lug disc kits are designed to work with all 71-87 2wd truck spindles, and all 71-91 Blazer, Jimmy & Suburban 2wd spindels that originally used 1 1/4" rotors.
6-Lug Front Disc Brake Kit, Includes for both sides all needed Inner&outer wheel bearings, new grease seals, dust caps, Calipers, Brake hoses, Pads, 12" 6 Lug Rotors, spindle nuts, requires the use of 1971-87 spindles or our standard or drop spindles. Will not work with stock 63-70 spindles. 2 wheel drive only. Will not work with some stock drum brake rims.$219.95 or 5-Lug Front Disc Brake Kit, Includes for both sides all needed Inner&outer wheel bearings, new grease seals, dust caps, Calipers, Brake hoses, Pads, 2-12" 5 Lug Rotors with hubs, spindle nuts & cotter pins, requires the use of 1971 -87 spindles or our standard or drop spindles. Will not work with stock 63-70 spindles. Perfect kit to replace all those used front brake & bearing parts with new. 2 Wheel drive only. Will not work with some stock drum brake rims.$209.95 Both kits are designed to replace all brake wheel related parts with all new parts. You will find them at the following link http://www.gmcpauls.com/Brakes&Steering.htm GMCPaul |
