Old 02-12-2006, 06:36 PM   #1
Bowtie67
Bowtie67's Avatar
Back Spacing calculation
I am not 100% sure and want to be before I order my new rear rims, There will be wheel tubs so inner dimensions not an issue. Frame width is 34"
My outside measurement inbetween the rear fenders (stepside) is 73.25"
Axle width drum to drum is just under 55"
Rims will be 12" wide Tires are 15" wide
73.25 - 2.25 (rounded off) space btween tire & fender = 71" (1 1/8 per side)
71" - 55" = 16 / 2= 8 would mean a 4" BS
4" + 1.5 = 5.5 BS (1.5 is for tire over hang)
Anyone else come up with anything ??
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 02-12-2006, 08:15 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Back Spacing calculation
Just remember that a production 12" rim will ACTUALLY measure 13" from the outside edges of the rim. The 12" measurement is the tire bead surface. I like to take a "know rim",...(like a 15x8 truck ralley) and use it to measure off of. Mount it under the truck, (without a tire), and add or subtract inches to put the wheel where you want it. I hope this helps.
Keith
Convert to disc brakes.
Old 02-12-2006, 09:48 PM   #3
Hart_Rod
Hart_Rod's Avatar
Pretty good chart on Budnik's website:
http://www.budnik.com/techInfo.asp
Hart_Rod is offline   Reply With Quote
Old 02-12-2006, 10:54 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
http://www.earlywheel.com/choosing.html has a simple way to find out what you need down on the bottom of the page
