Old 02-15-2006, 11:10 PM   #1
kanuck
6 stud standard?
just a quick question on if all 6 lug wheels are the same spacing or are they different from vehicle brand to brand?
Found some rims from a 1990 Suburban and wonder if the 6 lug stayed the same till then and up into any newer trucks?
Thanks for any info...
Hagen
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 02-15-2006, 11:25 PM   #2
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: 6 stud standard?
I beleive they stayed the same, the only difference might be when you get 4x4 wheels, the hole for the center hub may be different size than a 2wd.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 02-15-2006, 11:38 PM   #3
kelsfine69
18 Till I Die
kelsfine69's Avatar
I got 86 4x4 ralleys on my 69 and they fit ok. A lot of guys do this.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 02-15-2006, 11:41 PM   #4
The only other problem would be early drum-type 2wd on later disc 4wd.Also,the 88-up type are more inboard/less dish or narrower track.I see the wheels in question are from a`90 Suburban.So,that`s a 4wd and you`re fine.
Old 02-16-2006, 12:10 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
6 lug AMC fit too, but you have to open up the center hols a little.
Those '90 burb wheels MAY have a real small center hole that won't work on the older hubs, and the back spacing would be WAY off and look flat out retarded.
Old 02-16-2006, 12:46 AM   #6
You`re thinking of the`92-up Suburbans.These would be the 4wd solid axle w/external l/o hubs:nub-type dog dish hubcap,8" rallye,or alloy 8-hole.
Old 02-16-2006, 12:35 AM   #7
Longhorn Man
open up the center hole a little.
The back spacing on them are a little funny too. I had 70-something wagoneer wheels on the front of my 69 GMC SWB. They were tucked in just a bit too much for my taste, and the rear ones woulda rubbed with the 275 wide rubber in back. (which is why I never looked for the others to make a complete set)
