07-21-2002, 01:11 PM | #1 |
72 Cheyenne
Will the H-Pipe give a better sound?
I have dual straight 2 1/4 pipes into flowmasters, will the H pipe set up give abetter sound? I'm having 2.5 pipes put in and wanted to get some input, thanks.
07-21-2002, 01:13 PM | #2 |
its all about the +6 inches
They will sound a little differant...slightly more quiet.
07-21-2002, 02:40 PM | #3 |
It will sound a bit more tuned IMO.
Life is good with a 6-71 supercharged 355 in a 72 camaro |
07-21-2002, 02:58 PM | #4 |
Half a bubble off!
It made my truck sound better. I would never put on a dual exhaust system without the H pipe. It equalizes the two sides for a sweet even sound, loudness depends on the mufflers you use.
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
07-21-2002, 03:05 PM | #5 |
Fabricate till you "puke"
Same here,I run an h pipe in every dual system since I tryed the first one.........a much "cleaner" sound........Al
07-21-2002, 06:39 PM | #6 |
Dion will try to stop by after work tomorrow. Monday and you can check out my new exhaust system then and let me know what you think then. You'll be able to hear one for yourself!
Smitty
Smitty '71 Short Fleetside Spring Valley, Ca. |
07-21-2002, 08:08 PM | #7 |
I just had an H pipe put on my 72. Hedman headers with 3" pipes, Flowmaster 40s and big tips angled behind the tires. It really does make it sound tuned. I love it.
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
07-21-2002, 11:33 PM | #8 |
72 Cheyenne
Cool, I just don't want to loose my low end rumble.
07-21-2002, 11:48 PM | #9 |
Half a bubble off!
Your low end rumble will sound sweeter than ever! H pipe is the only way to go.
07-22-2002, 02:58 AM | #10 |
huh?
I agree Wilfred!
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
07-22-2002, 07:49 AM | #11 |
Slowly getting CRSS...
adding an hpipe made my exhuast resonate more
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
07-22-2002, 11:54 AM | #12 |
Before and After
Is there a way to determine where the crossover should be? would it depend on the size of pipe? I heard that you should run new exhaust for about 1/2 Hour, the pipe will darken and that is where the optimum place for the H pipe. If this is true, it would take 2 trips to the muffer shop, who has time for that?
Where does you H pipe fit in your system, how far back from the end of the collector? Just want to be able to do mine once.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
07-22-2002, 12:11 PM | #13 |
You can paint the pipes with some cheap paint, then run it a while to see where the paint stops burning..... that should be about the right place for the h pipe. with that said, on a street vehicle,i try to put the H pipe just behind the trans crossmember,as i dont need any extra heat under the trans pan,or the headaches of trying to remove the pan with a pipe in the way. ......Al
