Old 02-20-2006, 05:13 PM   #1
TraderJon
TraderJon's Avatar
brake booster
Has anybody ever done away with the power brake booster bracket & mounted the booster directly to the firewall ?
Can this be done?
It hangs way out in the engine bay on my 67,swapping from sbc to bbc later this year, vlv covers almost rub it,,,thought about shortening the brake pushrod arm?
TraderJon
TraderJon is offline   Reply With Quote
Old 02-20-2006, 05:19 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: brake booster
yes, in various ways -- here are a few links --the last link is for a 79 booster --link is broke
http://67-72chevytrucks.com/vboard/s...d.php?t=183125
http://67-72chevytrucks.com/vboard/s...d.php?t=175714
http://67-72chevytrucks.com/vboard/s...d.php?t=165344
To use the oem pedal rod hole the booster rod is 8.5" to the center of the rod hole from the firewall mount. Make adjustable if possible.
You will lose about an inch of pedal travel -- before same braking-- brakes the same otherwise.
dennislbrooks is offline   Reply With Quote
Old 02-20-2006, 08:09 PM   #3
TraderJon
TraderJon's Avatar
Re: brake booster
Thanks Dennis
Good info,,,,,Wouldnt you know i just had a 81 truck hauled off after i took all the parts i needed,,,it had hydro boost on it .
JFD
