02-22-2006, 07:36 PM | #1 |
Active Member
5on5 axles from 76 into 67
I have a friend that will give me the 5-lug axles out of his 76 (he has already given me the front suspension...complete control arm to control arm) Will these axles slide right into my 67 12-bolt rear-end? I've seen "conversion axles" like those offered from ECE, so I'm assuming it won't be this easy, but I was hoping maybe they could be shortened or something cheaper than conversion axles.
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
02-22-2006, 08:08 PM | #2 |
its all about the +6 inches
Re: 5on5 axles from 76 into 67
They are too wide.
Some ppl will make spacers to place between the backing plate and the housing, however, that is a bad idea. The section of the shaft that rides on the bearings is hardened more than the rest of the axle. By installing a long shaft in there, you will not be rolling on the hadened surface. While many have done this in the past, it is a prime recipie for a wheel to fall odd (with hub intact) and leave you skidding in circles in the middle of the freeway doing 70 MPH... on your 1/4 panel. |
02-22-2006, 08:22 PM | #3 |
Doesn't ECE have a kit to change over 73-87 axles to to spring mount and the pan bar? That might be an easier route.
