Old 02-25-2006, 04:37 AM   #1
13lazer
13lazers' blazers
13lazer's Avatar
Question wheel spacer ?
i just got a nice set of 6 lug rims from a lexus suv. they look good on my c5 blazer. i need to add about 1-1/2" spacer to get them to fit. i know i should eat my vegetables, wear my seatbelt, and not use wheel spacers to compensate for backspacing. im running 6 lug drums in the rear 6 lug discs in the front. my main problem is that the rear wheels barely clear the joint at the wheelhouse/bed floor. are some spacers better than others? what are some of the differences? im gonna check ebay, i appreciate any advice before i bid.
13lazer is offline   Reply With Quote
Old 02-25-2006, 08:22 AM   #2
vtblazer
vtblazer's Avatar
Re: wheel spacer ?
Never seen a spacer that wide for sale.
Most are 1/2 - 3/4 but good luck in the search.
Not sure I'd want to run one that wide, JMO.
vtblazer is offline   Reply With Quote
Old 02-25-2006, 12:24 PM   #3
jhow66
jhow66's Avatar
Re: wheel spacer ?
Orangeuavol has 1 1/2" spacers on the rear of his Blazer to make it even with the front. Can be purchased from different dealers --he found his on Ebay. Spacer bolts to drum with original studs--spacer then has studs already installed for wheels.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-25-2006, 01:01 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: wheel spacer ?
I think Orangeuavol has 1" spacers for a total of 2". My understanding is that the rear track is 2" narrower than the front.
Have you checked the front wheels to see if they clear the hubs? You may have to get them machined out to fit.
Ya might check with someplace like Stockton Wheel to see if they can change the off-set on the wheels rather than run huge spacers.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-25-2006, 04:05 PM   #5
jhow66
jhow66's Avatar
Re: wheel spacer ?
Sorry but you are wrong. Orangeuavol (my son) has 1 1/2" spacers. The rear track is 3" shorter. Both ends now measure the same. I will get back to this post and show you where you can buy the spacers if I can find the site.
Old 02-25-2006, 03:19 PM   #6
Medicanman71
Medicanman71's Avatar
Re: wheel spacer ?
At that point its probably cheaper to find nice ones you actually like - no one gave me any help when i asked about spacers either!!!!
when i looked on ebay i found hardly anything for trucks, what i found and posted wasnt the correct spacers...
if some one sees a pair on ebay that would work feel free to post them up
Medicanman71 is offline   Reply With Quote
Old 02-25-2006, 04:25 PM   #7
Medicanman71
Re: wheel spacer ?
If it's possible that would be awsome, thanks
Old 02-25-2006, 04:48 PM   #8
jhow66
jhow66's Avatar
Re: wheel spacer ?
These should help:
http://www.coloradok5.com/wheelspacers.shtml
Old 02-25-2006, 04:52 PM   #9
jhow66
jhow66's Avatar
Re: wheel spacer ?
Goofed-lost the other one--posted the same one twice. Will try again.
Old 02-25-2006, 04:58 PM   #10
Medicanman71
Re: wheel spacer ?
viola, thanks for the link,, i hadnt even looked over at coloradek5
Old 02-25-2006, 05:46 PM   #11
jhow66
jhow66's Avatar
Re: wheel spacer ?
This looks like your best bet:
http://www.ezaccessory.com/Wheel_Ada...6550-6550t.htm
Old 02-25-2006, 05:49 PM   #12
bouncytruck
SKINNY TIRES RULE!
Re: wheel spacer ?
No worries. I just though the track was 2" different. For some reason, I had it in my head that he only had to use 1" spacers. Good to know.
bouncytruck 1972 K5
Old 02-26-2006, 04:07 AM   #13
13lazer
13lazers' blazers
13lazer's Avatar
Thumbs up Re: wheel spacer ?
thank you jhow66 those look like keepers. i've also gotten some cool lexus low profile 18's with a 5x4.5" pattern. im sure they have adapters for 6x5.5"to 5x4.5"
Old 02-26-2006, 07:30 AM   #14
vtblazer
vtblazer's Avatar
Re: wheel spacer ?
I was mistaken as well, they seem to be everywhere now.
Here's another one.
http://www.spidertrax.com/s.nl;jsess...c=2&category=4
Old 02-26-2006, 08:21 AM   #15
JMac11
JMac11's Avatar
Re: wheel spacer ?
I am thinking spacer have came a long way, but my first impression was inline with VT. I know for many years NHRA would run you off for having them on a car. At best, it would be an item I inspected regulary.
JMac11 is offline   Reply With Quote
Old 02-27-2006, 04:21 AM   #16
13lazer
13lazers' blazers
13lazer's Avatar
Re: wheel spacer ?
as a structural steel and welding inspector, torquing is my business. i have a solid background in metallurgy and fabrication. my adapters will be looked at often
would these look cool on a 2wheeler or what?
Old 02-26-2006, 11:56 AM   #17
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Re: wheel spacer ?
http://www.skulte.com/product_info.p...6401580c17d438
This guy makes them to adapt different # of studs to each other. It will also push the wheel out about 2 inches.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
