02-26-2006, 02:01 PM | #1 |
chevelito
Spacer size to run w/disc brak conversion.
Hi guys,
For those that have changed from drum to disc brakes, what size wheel spacer do I use to run the stock rims and clear the brake caliper? I got the Mcgaughy drop spindle disc brake kit. tia, Jay I have this type of rim:
New deadline...when my son can drive. Aloha from Honolulu, HI |
02-26-2006, 02:47 PM | #2 |
its all about the +6 inches
Re: Spacer size to run w/disc brak conversion.
I know 4X4 wheels will clear. Personally, I'd seek out proper wheels rather than use spacers. your state inspection is rather crazy over there and if they saw the spacers, you are sure to fail.
02-26-2006, 03:31 PM | #3 |
I had to run a 1" spacer on a 66 1/2 ton with 66 stock wheels. This will leave your rear wheels narrower that takes about 1.5 " on each side to even out depending on your year.
02-26-2006, 05:30 PM | #4 |
I used 5/8" spacers on my '69 when I switched from drums to ECE discs.
Hook'em |
03-14-2006, 03:23 AM | #5 | |
chevelito
Where'd you get them? Thanks, jay
03-14-2006, 10:16 AM | #6 |
Mine came from Pep Boys, but you can find them online.
Hook'em |
03-14-2006, 01:03 PM | #7 |
I was giving a site off of Ebay but I found them a little cheaper on this site http://www.ezaccessory.com/SearchRes...ularity&Page=2
68 Chevy short wide air cab 4/6 on the drop 327 small block Front disc Frame "c" sectioned Gaylord bed cover Last edited by riden2low; 03-14-2006 at 01:05 PM. |
