Old 02-27-2006, 01:17 AM   #1
captainron67
captainron67's Avatar
Question I need help on my 67 c10
I just bought a 67 c10 small window original truck with a six cylinder. Anyways 6000 later and a 383 stroker I need to know if there is a different clutch linkage set up cause i cant get this one to fit with the headers. Any pics would be great or info.
captainron67 is offline   Reply With Quote
Old 02-27-2006, 02:17 AM   #2
davidh
davidh's Avatar
Re: I need help on my 67 c10
running a 3speed? Maybe you should get some shorty headers. Then it will clear.
davidh is offline   Reply With Quote
Old 02-27-2006, 02:22 AM   #3
MDC
MDC's Avatar
The headers are most likely the problem. Different brands will fit differently. Like davidh says, shorty's are probably best. I have that on my list to do also. The PO just hammered the back tube until it cleared.
BTW Welcome from N Texas
67 C10 Shortbed 327
05 F150 4x4 NO APPOLOGIES 's
02 Xpress X19 02 Yamaha VMax 150
www.xpressboats.com
Nothing says 'poor craftmanship' like wrinkles in your duct tape
MDC is offline   Reply With Quote
Old 02-27-2006, 10:20 AM   #4
Do the headers run into the linkage tube itself,or one of the two arms(tabs)that are on it?I have relocated one before.Clean all the grease out,cut it off and reweld out of the way.
Old 02-27-2006, 10:29 AM   #5
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Are you trying to run the 6 cyl clutch linkage? Its differante for a 6 to a V8
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 02-27-2006, 06:21 PM   #6
captainron67
Yes im running long tube headers and a 3 speed(runs like a sewing machine, but wicked at high rpms). My problem I think i need to jack the motor up on the drivers side then put the z bar in. I dont even no if the linkage hits the header yet. Also I noticed that my engine mounts are on the rear two holes while my buddies auto runs in the front two hole. Is that supposed to be different on auto vs. manuel?
Old 02-27-2006, 08:35 PM   #7
davidh
davidh's Avatar
front holes are 8cyl and 6cyl are rear.
Old 02-27-2006, 10:46 PM   #8
71chevytruckguy
71chevytruckguy's Avatar
when the motor's in the front 2 holes, flowtech headers will clear. what i have on my '69. got them at autozone for $85.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 03-03-2006, 03:16 AM   #9
captainron67
Thanks for info I just cut the arm off the linkage and re welded it on in right position.Works great.
