Got passed by my own tire!
Yes, did some work on the hubs this weekend.....put everything back together, I know I wrenched on all the lugs pretty hard.....but it looks like the lugs on the drivers side managed to loosen themselves over the last 100 miles.......so here is my problem.....what do I need to get this rig back on the road? I have found both brake pads, and the drum, but the springs, the adjuster, and the backing plate of axle seem to be gone or ground flat......am I gonna be able to find all of this stuff at napa/advanced/autozone....anywhere? Parts numbers would be appreciated.
Also, is there any serious damage I should look out for? For anyone wondering, I managed to make it about 600 feet down the road.....hit a bump hard, hit the ground, lost all steering and couldn't get the damn thing to stop.....managed to get it slowed down enough before putting it into a 12' deep ditch....during all of this I was fortunate enough to see the tire fly past me.....found it 400 feet behind me.....and the drum 300 feet behind the truck.....the good news, it was on an empty dirt road....no one around, and I was able to leave the truck there while I walked to my house about half a mile down the road.......got my car, bought some lug nuts, jacked up the truck, got the wheel back on, and drove the poor girl home at 5mph.
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
Re: Got passed by my own tire!
Damn what a bummer, glad it wasnt 10000000X worse... sorry i cant help. as far as your wheel and tire flying off, seems like you did not bad, no body damage! Couldnt have picked a better spot to fly off at either..
![]() Join Date: Sep 2005
yeah try carquest if you got one of them or any advance auto any major parts store should have the parts you need
Professional Grade
Sounds like a good time to upgrade to a newer D44 or 10 bolt with disk brakes to me!
Just be happy you didn't cause any major damage to your truck!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 02-27-2006 at 10:26 PM. |
#5 | |
I understand those drums are real hard to find. You may have to get a newer disk front end anyways. This is the PERFECT time to upgrade.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Damn man glad you and the truck are reletively ok. that really sucks! Nice truck though.
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() |
i'd say a junkyard would be a good place to find a new backing plate, or you could check on the parts board//i really wouldn't place any faith on the one you drove down thw road on
#8 | |
What a blessing that the incident occured on a dirt road and so close to home!
![]() Quote:
Might as well pull the inner axles and check the u-joint crosses if you replace the backing plate. Use a torque wrench next time to verify the tightness of the lug nuts. Go for 90-120 ft lbs for 9/16" studs, as per the service manual (SPECIFICATIONS 20 in my '71 manual). Retorque after 100 miles. Hope the budget allows for a disc conversion. I know how that is...
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 02-28-2006 at 03:24 AM. |
Glad to see there was little damage. Time to buy a new set of underwear I bet
"You can take the man out of PA, but you can't take PA out of the man" |
Gone Fishing
That sucks. At least very little damage occured
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
So,the drum and wheel were seperate?Sounds like you didn`t finish that corner after your bearing service.I don`t know how one would effect the other.Sounds like your spindle nuts spun off.Was there a funny washer with tabs on it between the spindle nut?Glad it wasn`t worse!I`m sure someone could set you up with what you need right here in the parts section.
no, the hub is still on there, there is a locking washer between the two spindle nuts....but the drum goes over the hub....when the wheel came off....the drum went with it.....not sure if it was before or after the front end hit the ground......looks like before as the drum is in good condition still.....I think that retorque after 100 miles is what nailed me.....with the washboard road I live on....I probably should have done it at 30 miles.....because I hit a deusie of a pot hole right before this happened....enough so that I think I actually traveled a couple of feet down the road before the axle hit the ground.
I KNOW i need a new backing plate......4,000lbs truck + 50mph X down a dirt road = enough friction to sand the plate flat from round.....its not bent, its GONE! I am planning on doing the swap, but I JUST put the bearings in, the shoes and drums look to be brand new.....and I am hunting around for a d60 to put in there.....so I think I will throw some smaller bucks at getting this back on the road, and work on the d60 plan in a bit. (plus....I have no way of getting a newer D44 home without my trucks bed (lol) ) btw, when I finally got it to stop, I was very happy about how the whole thing worked out......it could have been miles away from my house, it could have been on a busy street, I could have hit someone else......on a dirt road, .5 miles from home....where I could just leave it, and take care of it on my own......with only relatively minor damage.....no complaints here....only counting of blessings!
Maybe that bump was the tire falling off(drop),then rolling up under your truck(lift).Maybe???
Sorry,now that I looked back at the pictures,I see the hub intact on the spindle.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-28-2006 at 09:30 AM. |
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
Bad times
Glad to hear you are all right.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
#15 |
I have a 67 parts truck which might have everything you need to put her back on the road.. Drop me an email w/contact info and if it fits, I will send it all Free plus shipping.
#16 |
PM sent!
#17 |
Resident Curmudgeon
![]() Join Date: Dec 1999
Bad news for you. Those 1970 3/4 ton 4x4's front end parts are one year only, due to it being the only year for an open knuckle drum FE. Your donor will have to be a 1970 3/4 ton 4x4 unless you change out the entire D44. You might want to check with Bill Athey 540 636-7405, He's a board vendor and I sent a complete 70 3/4 ton 4x4 D44 FE down to him several years ago. It had the backing plates but the drums were gone.
You may want to find a disk brake D44 and replace the whole thing at this point. I feel doing that for the sake of disk brakes alone is foolish, but from the parts interchangeability and availability, it's well worth it.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#18 |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Wow...That sux. Glad to see you made out alright for the circumstances.
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
#19 |
-Chris
![]() Join Date: Sep 2002
I have a 70 c-10 1/2 ton and I re-did my brakes about 2 weeks ago. I got all new hardware, pads, wheel cylinders and drums from advance auto. If its not in stock, im sure they can order it all for you and have it next day. Try your luck there. Best of luck to ya with that. Just be happy theres no body damage.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
#20 |
will open knuckle/closed knuckle change the backing plates and drum brake hardware?
#21 | |
Resident Curmudgeon
