i recently purchased a 67' burb with a straight 6 and 4 speed tranny... i want to put a big block with a turbo 400 or 700r tranny.... i have found a 77 chevy with a 454 turbo 400 and 3/4 ton rear-end.... will this be a difficult swap? has anyone done this? any input is greatly appreciated...
'67 sb 500+ hp 406 3200 stall ram air tubbed bed liner fuel cell battery box in bed 18's '67 burb 6 cyl 4 speed bone stock 05 black GTO |
Re: straight 6 to big block?
Im new to these, but it should just be motor mounts/perches, crossmembers and linkages
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
Above mentioned items plus radiator, shroud, steering column, different throttle rod maybe, possible larger fuel lines, a bit of wiring. Shouldn't be too tough of a job, everything you need can be bought either through vendors or board members.
"You can take the man out of PA, but you can't take PA out of the man" |
if you use the 77 crossmember, bolt in but have to drill so holes, if the front end is 1/2 bolt it all in, cheaper parts better ride, motor mounts are cheaper etc.
With the 77 donor strip everything and bolt it in.........just about only thing is that the 67 frame doesn't have a dimple for P/S no big deal, either go with what member wes did or get the kit from a vender. Have fun, want a 67 burb! |
